xs or optima
D3400 will fit nicely in an s10 with some slight modification to the battery tray.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
in before lock! no but we had an optima blue top powering one of our golfcarts radios and led's (never used) and horns, and yeah the battery went completely to shit in about 6-8 months..
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
this isnt a vs thread i just want toknow what would be better to use up front. my optima is 3yrs old so i wanted to see if itd be ok to leave up front or just get a brand new d3400 up front
08 Ford F150
If it was me i would go with the d3400. Its a beast battery.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
you asked a forum that nuthugs xs power weither you should use the optima or the xspower, the answer your gonna get was written in stone before you even started the thread making it kinda pointless.
when comparing 2 different brands asking which would be better for you to use its a vs thread.
your question summed up, What better for me a yellow top optima vs a xspower d3400?
ive seen threads that where further from a vs thread then this get locked with in the first 3 posts. maybe the mods are on a bass break? siting in there rides.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 943 Guests (See full list)
