Audio Customs Posted October 24, 2012 Report Posted October 24, 2012 her you go this should help you http://toolmakermetalworkz.com/index.php cone area http://www.stevemeadedesigns.com/board/topic/6819-cone-area-of-a-subwoofer/ 4th order band pass basic http://www.stevemeadedesigns.com/board/topic/126478-basics-of-a-4th-order-bandpass-enclosure/ this is Torres box calculator My GUI Box Tuning Calculator Download - Updated 8/18/2012
Tim Lam Posted October 26, 2012 Report Posted October 26, 2012 I think 3/0 would be too big, how does it tighten, a screw or clamp they are tightened with hex head screws. if you don't want to wait definitely go with Stinger, slightly pricey, but i have NEVER been disappointed in the quality of ingenuity of their products!
Tim Lam Posted October 26, 2012 Report Posted October 26, 2012 http://www.amazon.com/Stinger-Shoc-Krome-Series-Ground-Reducer/dp/B001H4W86C/ref=pd_sim_e_1 they also make "gold" plated ones
Tarball Posted October 26, 2012 Report Posted October 26, 2012 alternatively you can solder up the end of your KNU with siliver solder and then use a banch grinder to trim until it fits the way you want. You will need a soldering torch of some type. cheap effective easy no wait CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
ZachG Posted November 2, 2012 Author Report Posted November 2, 2012 alternatively you can solder up the end of your KNU with siliver solder and then use a banch grinder to trim until it fits the way you want. You will need a soldering torch of some type. cheap effective easy no wait I have mapp gas or cydaline I could use to do it but I rather wait to get the actual piece 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
ZachG Posted November 2, 2012 Author Report Posted November 2, 2012 http://www.amazon.com/Stinger-Shoc-Krome-Series-Ground-Reducer/dp/B001H4W86C/ref=pd_sim_e_1 they also make "gold" plated ones I may just buy the gold plated ones 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
