scooter99 Posted December 12, 2012 Report Posted December 12, 2012 I would say your rattles are coming from your entire back wall!! Tennis balls, I understand, help to stop the flex pretty well. Also that rear sliding window is going to give you some fits. It'll rattle loose eventually if it hasn't already. Might as well change it out to a solid window asap! Otherwise, sick as hell on 1200 watts!!! Facebook Page: S99Creations 2006 F250 Lariat Build
tacomaguy1 Posted December 12, 2012 Report Posted December 12, 2012 angle iron connected to the back wall with 3m panel bond, or bolted if you don't mind drilling through the back wall more, or weled if that's even possible Then the angle iron bolted to the port where it comes through would be solid Team Flex Issues
c.director Posted December 12, 2012 Author Report Posted December 12, 2012 I've heard of tennis balls, I don't think that one would fit, I may have to try. People say bolt, but unless I removed the bed I don't see that working, how am I supposed to get a wrench back there? My hand wont even fit very far. I'm using an old stick welder that would melt that metal in a heartbeat, but I know some people that do some lighter materials, I'm really thinking about welding some bracing, followed by MDF, then spray foam in between, should do the job lol Facebook: http://www.facebook.com/caleb.arnold.9809 YouTube: http://www.youtube.com/user/CustomAudioChannel?feature=watch
wmrcs Posted December 12, 2012 Report Posted December 12, 2012 Dude, that back wall is going nuts. You should meter it before and after you brace that to see what you gain just for fun E34 540iT/6
tacomaguy1 Posted December 12, 2012 Report Posted December 12, 2012 http://3mcollision.com/3m-panel-bonding-adhesive-08115.html for metal to metal without welding Team Flex Issues
graham0599 Posted December 12, 2012 Report Posted December 12, 2012 What i'd do is weld in 1/8" flat steel and basically cover the inner wall around the port. Keeps it flat but strong My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
c.director Posted December 12, 2012 Author Report Posted December 12, 2012 http://3mcollision.c...sive-08115.html for metal to metal without welding That stuff looks legit..expensive too lol doubt it will hold as good as a weld though, which is what I will probably end up doing. Facebook: http://www.facebook.com/caleb.arnold.9809 YouTube: http://www.youtube.com/user/CustomAudioChannel?feature=watch
OrangeJuiced Posted December 13, 2012 Report Posted December 13, 2012 You can weld sheet metal with an arc welder. Not sure how much experience you have though. Set the welder to about 40 amps and use some 1/16" rod. Don't do any long beads whatsoever. It is possible. 2001 GMC Sierra Build. Body dropped and Juiced
ccmotox99 Posted December 13, 2012 Report Posted December 13, 2012 how do you like those Obsidian's? I'm looking into getting me some -playing with different setups
c.director Posted December 13, 2012 Author Report Posted December 13, 2012 Dude, that back wall is going nuts. You should meter it before and after you brace that to see what you gain just for fun I should lol but the only meter I know is 2 hours away. how do you like those Obsidian's? I'm looking into getting me some Love them man, they get really nice down low with this setup..its right up there with sundown, skar, etc in my book. Edit: just saw your sig, I switched from sa12s (only 2) but if they were in similar setups I imagine you would loose just a tad on the meter with the obsidians, but the low end would be better. Facebook: http://www.facebook.com/caleb.arnold.9809 YouTube: http://www.youtube.com/user/CustomAudioChannel?feature=watch
