150db on apsm4k??? Dakota, Obsidian/Audiopipe 4th Order Blow Through
A few updates, not getting to work on it as much as I want because the transmission is being replaced. Hopefully I get it back today and can get serious with a few things!
Drilled all these nice holes while I didn't have the truck, turns out the lip wasn't as big as I thought lol
^^^Still gotta do some trim work in the back, which will be bedliner.
For the two runs a 0 AWG from front to back
Started rebuilding the back seat area, the batteries will be under two "mini" seats and some thick plexi over the amp area all trimmed out in grey/carbon fiber vinyl.
and a couple shots of the truck before it went to the shop.
Eventually plan to upgrade so an Sundown 3500 or something similar.
  • 1 month later...
UPDATES:
Ive been working a lot, and have a little to show for it.
Some Audiotechnix wire
Bracing:
Cut the trim panel for the back
and a few scores on a APSM 2000
Sealed up
Outlaw was .3 db higher, but at around 38 hz.
Probably gonna double the amp soon and see what it can do.
  • 1 month later...
Link to the Plasti DIp you used on your rims? They turned out really good! Everything turned out awsome. Really like the final tablet mount. Did you just use fiberglass to build the nipples for the tablet mount?
Its the basic stuff in a can at home depot, i used a razor after it dried to cut that lip. (rim had a groove I could follow). and yes I made the mount complete from fb, but ive changed it again.. lol
A couple updates, still so much to do.
In progress..
Pods started..
Hmmm...150 on apsm4k?? (through sealing/tweaking)
In the kick driver door open
Sealed
add me on facebook to see a lot of other builds I'm working on.
Okay man I must ask... does that tab cover your vents? I know where I want to mount my tab when I get it but it's going to be in the way of the vents... moving my climate controls should be no problem though
It does cover my center vents.. AC is not all the great in this truck anyway
  • 11 months later...
