My car rubs when I have passangers in the back + system. HELP
I have 20" inch wheels, 20x8 and it rubs(bad!) when I have passengers in the back. I plan on adding another 12 inch sub meaning its going get really bad if I don’t find a fix. It used to rub with just me driving so I brought spring spacers (not so safe) and it stop the rubbing. But now I plan on having passengers and my audio system.
I have no money to buy new set of rims with different offset/size 20x7.5 fit perfect according to others.
Do you guys think welding some of the coils would be ok? therefore no way of it to drop any lower when hitting bumps/turns?
FYI: car is not lower, stock height on 20s, only back/rear rubs front is ok.
Any ideas or advise would be much appreciated. Thank you
CAR: 2005 Acura Tsx
Sounds like you're in a pickle, suspension work is never cheap. I would have suggested off set as well. Try craiglisting your rims for a trade?
Also you might be able to find an offset spacer, from what I've heard they are cheap.
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
air shocks
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
This well probably be my last resort, thanks
BODY LIFT! lol
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
Do you need 20s on a car ? What vehicle? What in the trunk? How big are passangers ?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Depending on the type of vehicle you have, you can get overload springs and heavy duty shocks. Buy ones to accommodate the weight of your install. This will restore the ride height to factory. Personally, I do not like air ride since the parts tend to wear out more rapidly than the metal of coil or leaf springs; hence, I removed my factory air ride and went with an overload coil and heavy duty shock on my marquis. Stiffer ride unloaded, rides perfect with my modest system and retains the height with passengers.
Barstad
No, I do not need 20s but want them. Car is a 2005 Acura TSX, passangers range from 145lb up to 300lb each. My audio system consis of two eclipse titanium 12s with 2 amps and a kinetik 1400 battery etc.
  • Who's Online   0 Members, 0 Anonymous, 1677 Guests (See full list)
