FamilyB4Others Posted October 24, 2012 Report Share Posted October 24, 2012 I have 20" inch wheels, 20x8 and it rubs(bad!) when I have passengers in the back. I plan on adding another 12 inch sub meaning its going get really bad if I don’t find a fix. It used to rub with just me driving so I brought spring spacers (not so safe) and it stop the rubbing. But now I plan on having passengers and my audio system. I have no money to buy new set of rims with different offset/size 20x7.5 fit perfect according to others. Do you guys think welding some of the coils would be ok? therefore no way of it to drop any lower when hitting bumps/turns? FYI: car is not lower, stock height on 20s, only back/rear rubs front is ok. Any ideas or advise would be much appreciated. Thank you CAR: 2005 Acura Tsx Link to comment Share on other sites More sharing options...
Joshex Posted October 24, 2012 Report Share Posted October 24, 2012 Sounds like you're in a pickle, suspension work is never cheap. I would have suggested off set as well. Try craiglisting your rims for a trade? Also you might be able to find an offset spacer, from what I've heard they are cheap. 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here Link to comment Share on other sites More sharing options...
Tarball Posted October 24, 2012 Report Share Posted October 24, 2012 air shocks CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
FamilyB4Others Posted October 24, 2012 Author Report Share Posted October 24, 2012 Sounds like you're in a pickle, suspension work is never cheap. I would have suggested off set as well. Try craiglisting your rims for a trade? Also you might be able to find an offset spacer, from what I've heard they are cheap. This well probably be my last resort, thanks Link to comment Share on other sites More sharing options...
FamilyB4Others Posted October 24, 2012 Author Report Share Posted October 24, 2012 air shocks Where can I order these from? looks like it might just work for me. Thanks Link to comment Share on other sites More sharing options...
adam6604 Posted October 24, 2012 Report Share Posted October 24, 2012 BODY LIFT! lol Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi. Audio: Two 10" Alpine Type R's ( 1000rms models ) Hifonics BRZ 2400.1D @ .5 ohm Two Kinetic 1400 batteries ( soon to have XS power under hood ) Tsunami 1/0 Awg wire throughout truck. Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine. Exterior: 17"Dick cepek rims with 33" Toyo MT tires Bushwacker fender flares Magnaflow true duel exhaust LED tail lights with Projector headlights Plasti-dip fun coming soon! Link to comment Share on other sites More sharing options...
HunterJohnson Posted October 24, 2012 Report Share Posted October 24, 2012 stiffer springs or get smaller rims with higher off set Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
MIKE-2U Posted October 24, 2012 Report Share Posted October 24, 2012 Do you need 20s on a car ? What vehicle? What in the trunk? How big are passangers ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
photochrisb931 Posted October 24, 2012 Report Share Posted October 24, 2012 Depending on the type of vehicle you have, you can get overload springs and heavy duty shocks. Buy ones to accommodate the weight of your install. This will restore the ride height to factory. Personally, I do not like air ride since the parts tend to wear out more rapidly than the metal of coil or leaf springs; hence, I removed my factory air ride and went with an overload coil and heavy duty shock on my marquis. Stiffer ride unloaded, rides perfect with my modest system and retains the height with passengers. Barstad Link to comment Share on other sites More sharing options...
FamilyB4Others Posted October 24, 2012 Author Report Share Posted October 24, 2012 Do you need 20s on a car ? What vehicle? What in the trunk? How big are passangers ? No, I do not need 20s but want them. Car is a 2005 Acura TSX, passangers range from 145lb up to 300lb each. My audio system consis of two eclipse titanium 12s with 2 amps and a kinetik 1400 battery etc. Link to comment Share on other sites More sharing options...
