Running multiple alts
So I have no AC unit, want to put a second stock alt in that location. Now as far as putting on the alt and making sure it runs, do I need to have a wiring harness for it, to connect it to my computer or how does that work? I was going to be going to a pick and pull and get a alternator for cheap.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
All you need to do is figure out how the alt turns on. GM alts are a 1 wire turn on so all it needs is a switched 12v signal
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Ohk, what I was thinking, when I go and find an alt, just cut the wires that are already connected to the one I am going to get. Then just extend them into the ones already in my car.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
91 civic hatchback DX 1.5L i believe
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
how many wires are on your stock alternator?
My 240sx is a 4 wire, 1 4ga power, 1 ground, and a 2 wire connector. The larger wire into the connector runs to the battery so that it can sense when to kick on, and the smaller one is for the dash light. I ran the power output wire (positive) on my second alternator directly to the rear battery, ran a ground to the rear battery. I spliced the dash light wire into the stock alternator's harness. I ran the battery sensing wire to the rear battery as well. I could have run the ground to the chassis, but the car is pretty rusty and I wanted the best connection possible. I could have also spliced the battery voltage sensing wire into the stock harness and run the power output into the front battery, but since my amp is pulling from the rear battery, I wanted the power to go directly there, with as little resistance as possible.
Not sure if your honda is the same, but since they're similar years and both Japanese, I would assume they are similar.
from what i've seen, if someone says they have a 3 wire alt, that means there are 3 wires on the harness that clips into the regulator on the side. you dont count the main charging/ground wires that go to the battery.
Sorry, brain fart, I meant 2 wire....been a long day.
  • 1 month later...
do people who have multiple alternators have custom belts built?
I believe it depends on the location of the alt, for me I should be able to use a standard belt and be fine, if your alt is in a odd position from normal, or have more than one in certain spots that are not normal yeah. Just need to make sure you can fit a belt where you fit your alt.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 1358 Guests (See full list)
