battery selection help
My factory batteries seem to be failing (die in 10 min if i leave my lights on) so im looking for replacements. i was looking at optimas, basic oem replacement AMG types, and these kenitic things i had never heard of. currently i have the factory batteries, 2 750CA in parallel. I am running a ZX 1500.1, FI BL, MTX sterio amp, a 5KW power inverter, a 12,000Lbs winch, off road lights, and a 55W digital head light kit.
with all this taken into consideration and knowing that what ever batteries i place in here will be used for starting as well as powering everything. what batteries should i go with? I have no plugs so there is only a fuel pump to keep the engine running while things are on. i also live in MN so it needs to work well in very cold weather.
anyone have any recommendations?
nothing, gutted
What do you use your power inverter for and how much use does it get?
What type of amperage does your alt put out?
Answers to those 2 questions will lead you in the right direction. You MAY need a bigger budget.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i run my inverter for saws, lights, drills, compressors, ect. id say 1/4 is about 20% usage, 1/2 is about 50-70% usage and 1/4 70-100% usage.
my alt is factory with a HO rebuild kit, it puts out around 180A
nothing, gutted
  • Who's Online   0 Members, 0 Anonymous, 2276 Guests (See full list)
