donberto Posted November 7, 2012 Report Share Posted November 7, 2012 Hey corona jeff or raptorman, as previously discussed I am about maxed out on space, I punched into Torres calc and if I use 2 2in by 9in ports it gets the tuning to where you advised, but will that be enough port for the sub? Otherwise I might have to just go with sealed. Tried going to 3 or four in ports but it raised it back to the mid 50 hz range. Quote Link to comment Share on other sites More sharing options...
CJ18 Posted November 8, 2012 Report Share Posted November 8, 2012 2 port 2"x 9"? Are you talking about 2 2" aero ports? Quote Link to comment Share on other sites More sharing options...
corona_jeff Posted November 8, 2012 Report Share Posted November 8, 2012 Port area is way to small. You need to make it larger Quote Link to comment Share on other sites More sharing options...
donberto Posted November 8, 2012 Author Report Share Posted November 8, 2012 (edited) Yeah aero or pvc. With the dimensions i have to work with inner 15 in w, 10.5 d, 16.5 h the only way I can get the tuning down to 36.08 hz is to go 16.5 tall, 5/8 wide and 24 in long for the vent. right now it's tuned to 53.21. existing vent is 1 in wide 16.5 tall and 13 in long. will 5/8 gap restrict to much? Edited November 8, 2012 by donberto Quote Link to comment Share on other sites More sharing options...
donberto Posted November 8, 2012 Author Report Share Posted November 8, 2012 (edited) alright after some time I think i have got what you adivise. 22in high 16.5 wide 12 9/16 depth. port 15 in wide 1 in width 25 in long. .14 woofer dispalcement gives me gross of 1.97 and net of 1.25 and tuning frequency of 33.85 hz. Please check my calcs and I will start rebuild this weekend. Thanks again fellas. On the Torres calc when you put in 25 in vent length it say physical is 23.25, do you build it 25 in long or 23.25? Edited November 8, 2012 by donberto Quote Link to comment Share on other sites More sharing options...
