DD-1 question *Vids included
Yea, I would double check with the 1khz 0db tone on your full range to start eliminating things. You had said you can use the RCA's, so use those to check max volume. You need to check the head unit output with both the 40 and 1khz 0db tones. Also is there a level volume for your ipod in the head unit settings? Turn that off as well or all the way down.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Go back to your sub menu and turn the filter all the way up. The EQ should be seperate and turn that to flat. Also i looked at your headunit on sonic and it states you also have a high pass. Turn that all the way up or down ( cant remember, but just read the manual from the DD1 and it will tell you) bass boost off on the deck. You may have to turn your sub level all the way up on the deck. Make sure you dont have a volume level for the ipod. If you do, turn that down.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
I would just measure the distortion level on deck alone first... instead of trying to do it through your amp man.. Have you already tried this???
Under Construction
2011 Malibu 1LT
12k DDM Tuning HID's 55W
Soundstream 6.5 components(front)
Inffinitty Kappa 6x9's (rear)
You make a good point about the sub level. Looks like there are several ways it can be done. I'm sure I will run the sub level over 0 at some point.
Some decks only reach their 4 v output if you turn the sub level up. Might wanna look into that. My DD1 serves me PERFECT!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   1 Member, 0 Anonymous, 614 Guests (See full list)
