Jessica Posted November 13, 2012 Report Posted November 13, 2012 no... 4 twt total and 4 mids total .. i got 2 sets of 2ts.. im sayin per ONE channel 2twt or 2mids then yes, 2 tweets per channel and 2 mids per channel i think you and him are talking about different things Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 ok... so after I do all this how I should set the crossovers in the HU for TWT and Mids? sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
MrSkippyJ Posted November 13, 2012 Report Posted November 13, 2012 no... 4 twt total and 4 mids total .. i got 2 sets of 2ts.. im sayin per ONE channel 2twt or 2mids then yes, 2 tweets per channel and 2 mids per channel i think you and him are talking about different things 4 channel amp and 8 speakers right? or have i once again, in this thread, missed some important info F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 no... 4 twt total and 4 mids total .. i got 2 sets of 2ts.. im sayin per ONE channel 2twt or 2mids then yes, 2 tweets per channel and 2 mids per channel i think you and him are talking about different things 4 channel amp and 8 speakers right? or have i once again, in this thread, missed some important info YES! 4channel amp and 2 sets of T2's = 4 twt and 4 mids sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 I gotta go to sleep now .. I will come back to this thread 2morrow .. Im willing for any help from You guys ! sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Jessica Posted November 13, 2012 Report Posted November 13, 2012 here. these crossover settings are just a suggestion. edit, dammit, get back in here lol Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
MrSkippyJ Posted November 13, 2012 Report Posted November 13, 2012 This is very similar to what I am running. 2 sets of T1s and a t400.4. Other than the differences in models, the only difference is I am only running one pair of tweets. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
alaskanzx5 Posted November 13, 2012 Report Posted November 13, 2012 here. these crossover settings are just a suggestion. edit, dammit, get back in here lol wrong on some of it but the wiring is correct. the head unit needs to be set to active/high,mid,low rca setting. to do that you have to take the hu out, find a switch ( the manual for the hu will tell you where to find it) set it to active and then push the reset button on the hu ( manual can actually explain all of this with pics ). then run the front(high) rca preouts to the front input on the amp. run the rear (mids) rca preout to the rear input on the amp. then the sub (low) to the sub amp. from there you need to turn the cd player on but do not turn the volume up at all, keep it all the way down. go to network 1 select low pass, go back, go to network 1 set the cross over point. go back to network 1 self low mid filter go to network 2 set to around 150hz. go to network 1 select mid high pass filter go to network 2 set to 25khz. go to network 1 selct high pass filter go to network 2 set to 3khz. now go back through the network one setting and select low pass then go to network 3 select octave slope. repeat for each crossover point. READ, the manual for you cd player will tell you how to do all of this with pics. if you dont have the manual google search pioneer deh-80prs manual. i knew in the first post i asked that i should have asked about his hu. but no of course i assume that if he had a hu that was able to do all this he would have mentioned it. my fault guys. i have the same hu and planning just about the same thing. but using 2 punch pro tweets and 2 punch pro 6" mids and a t400.4. 1 tweet per front channel and 1 mid per rear channel. tweets wired at 8ohms and mids wired at 4 ohms. then if i want more out of the mids and tweets i can buy 2 more tweets rewire to 4ohm and 2 more mids and rewire to 2ohm. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Jessica Posted November 13, 2012 Report Posted November 13, 2012 How is my diagram wrong? Please, i would like to know. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
alaskanzx5 Posted November 13, 2012 Report Posted November 13, 2012 How is my diagram wrong? Please, i would like to know. the wiring is right but when the deck is set for active the front rear and sub preouts change to high mid low preouts. that and if he did what you said with out changing it to active then he wouldnt have the control he could have by changing it to active. might have even created issues with the tweets and mids not being crossed over right. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
