OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 Cause now it has sth like front high pass filter and rear high pass filter two of each sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 And im sure its 80prs sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
alaskanzx5 Posted November 13, 2012 Report Posted November 13, 2012 yeah you have to change it to active and press the reset button look in the manual or download it from their website. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 I found the manual online and i think i still got one in basement.. Im thinkin about puttin the set of mids from the back to front door i just wanna make sure if i have enough room without doin any fiberglass work sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 Thanks for all input guys, im still confused about the hu setup but i do the wiring first and than i ask u more about tune up thanks!!!!!! sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
DubNDodge Posted November 13, 2012 Report Posted November 13, 2012 if running active you realy need a way to fully set crossover points for all signals, low, mid and high alike. you have to make sure each part of the system is being used in its most suitable situation including in it suggested freq range. if not you could harm the speaker and not get the sq your looking for. How would I go about setting the crossover for the mids? The tweets are not a problem if they only need hpf, but the mids need lpf and hpf but the amp only lets you select one. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Jessica Posted November 13, 2012 Report Posted November 13, 2012 if running active you realy need a way to fully set crossover points for all signals, low, mid and high alike. you have to make sure each part of the system is being used in its most suitable situation including in it suggested freq range. if not you could harm the speaker and not get the sq your looking for. How would I go about setting the crossover for the mids? The tweets are not a problem if they only need hpf, but the mids need lpf and hpf but the amp only lets you select one. The t660-4 will not work for HPF for your tweets. It will suffice for the HPF for your mids though. You would be better off getting a external crossover or a headunit that has the ability to band pass and high pass Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
DubNDodge Posted November 14, 2012 Report Posted November 14, 2012 I wasn't using the T660-4. I was just asking a question in general I was planning on using mb quart 4.80 It seems you answered my question though, I will probably just have to use an external crossover.. Yuck Anyways this was the settings on the amp that I posted on pg4 incase you didn't see that '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
DubNDodge Posted November 14, 2012 Report Posted November 14, 2012 Do you need a LPF on the mids or not? I have looked a good bit now for a LPF crossover and none of them cross at around 4khz. So I am starting to think that you don't need a LPF on them '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
OrzechNJ Posted November 15, 2012 Author Report Posted November 15, 2012 ok guys so i was trying to find a good spot for another set of t2 to my front door, and it looks like they gonna fit good on the bottom of the door the question is , if its not gonna look getto ? and i believe its 80prs, at least it looks like lol sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
