01 Hyundai Tiburon | Fuse/Wiring problems.
Ok I see now, I'm on my cell and its kinda slow
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Well if its a 500d or something then he just needs to go up to a 80 or 100 amp in that holder , but I don't see what size amp he has, only that its a Rockford.
I have the Rockford Fosgate T1500-1bdCP
good god rip all that wire out to much power not the right wire and up it to a 200 ANL fuse
For sure need 0ga , big 3 and the works for that amp! I think they do like 1800+ rms
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Can someone give me a list of what I need to do to get this system on its feet. I love the comments from all of you, but it becomes very confusing when 2 or 3 people are telling me different things. Thanks ahead of time for the help.
My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/
My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo
Had an amazing time bro! Die hard Meade fan!
-- My System -- 2001 Hyundai Tiburon --
(1) Rockford Fosgate 1500.1bdCP
(1) Rockford Fosgate 360.3
(1) Pioneer GM-D9500F
(1) Optima Yellow Top D34/78
(2) Pioneer TS-W3002D - 1000W RMS 12's
(1) iPhone 5s - 32gb White
(1) iPad Mini - 16gb Black ( 24/7 Headunit )
-- Wanted Upgrades --
(2) SP4 (15's or 18's)
(1) BC5500
(1) Mechman 320 amp Alt
(4) Optima Yellow Top D34/78
(1) Big 3 Upgrade Kit
Fix my other T1500.1bdcp
thats what im saying. this says fail with a topping of car electrical fire all over it. the t1500.1bdcp manual says 200amp fuse and has 4 gauge inputs. get an agm battery run 1/0 from front to rear batt. run 4gauge from rear bat to amp. fuse no less then 6" away from the rear battery between the amp and battery. then you should fuse the 1/0 wire going from front to back. if im not mistaken 1/0 is rated for 300amps, match the wires amperage rating to a fuse for that wire.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
shit he still going to get bad volt drop even with good wire, even if He has 2 battery's, dude u need a good alt!
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
not really
do my list first then if you feel you need it up grade the alt at a later time
also add to the list a Voltage meter
there not the best but you can get a stinger digital voltage meter for around 15 bucks to keep an eye on your voltage
list
1/0 wire front to back
power distro block
ground distro block
1/0 ground
200 amp ANL fuse
do BIG 3 upgrade
if you have money for it a second batt in the trunk
^^ right here he may know a thing or 2
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
that fuse would definitely be the problem. 60 amps aint getting you much out of a t1500.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1363 Guests (See full list)
