01 Hyundai Tiburon | Fuse/Wiring problems.
every one of those connections is a horrible connection. your underhood fuse is blowing right? Its an agu type fuse they dont come bigger than 80 amps
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yeah i would replace the wiring with 4gauge going into the amp. 1/0 from front to rear. that ground looks like is could use some more cleaning up. maybe even try to find a better ground like a seat bolt.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
u also have way to much wire exposed in all your pics! ya for sure u need to run 0 ga to back into distro block then 4 gauge. and are u sure thats a 200 amp fuse?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
good call, didn't think of that. get a anl fuse holder and a 200amp anl fuse.
still though what amp do you have?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
oh excuse me they make a 100 amp fuse now. in agu.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
like n8 said i have never seen over a 100 amp in that kinda fuse holder , if your amp pulls more then 100 amps that is your problem
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
lol nice spot 200 amp agu that would be funny sure your not reading the part that says 20v as in 20 volts and addin a 0 to it?
Alright, so take the current power wire out and swap that with 1/0. then get a Fused Distribution block 1 0 Input, 2 4 outputs? then wires the amps to that?
My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/
My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo
Had an amazing time bro! Die hard Meade fan!
-- My System -- 2001 Hyundai Tiburon --
(1) Rockford Fosgate 1500.1bdCP
(1) Rockford Fosgate 360.3
(1) Pioneer GM-D9500F
(1) Optima Yellow Top D34/78
(2) Pioneer TS-W3002D - 1000W RMS 12's
(1) iPhone 5s - 32gb White
(1) iPad Mini - 16gb Black ( 24/7 Headunit )
-- Wanted Upgrades --
(2) SP4 (15's or 18's)
(1) BC5500
(1) Mechman 320 amp Alt
(4) Optima Yellow Top D34/78
(1) Big 3 Upgrade Kit
Fix my other T1500.1bdcp
And I will take a look at the fuse again, the people at the car audio shop where I live clearly no nothing, Be right back..
(1) BC5500
The fuse says "AGU60A" sorry for the confusion.
(1) BC5500
  • Who's Online   0 Members, 0 Anonymous, 2182 Guests (See full list)
