2 12 in focus
focas23
What year for focus do you have? If its.a first or second Gen focus (2000-2007) then the Max width is 40" wheel well to wheel Well not 42".
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
How do u think I should do the box I also filled up my rear deck with 6.5 well there's a total of 16 mids 8tweets and now I want to build a good box but don't know Wat to do if a ported,tline,sealed or vented and if I should go with 12s 15s or what
I would do 12s as you originally planned
Here is a suggestion for the Mofos122x you mentioned Subs up/port back :
Enclosure Specifications:
Fb = 34.5Hz
Vb = 4 ft^3
External Height = 17 in
External Width = 39 in
External Depth = 19 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 39 x 19
Left & Right Sides = 17 1/2 x 14 3/4
2x Front = 17 3/8 x 14 3/4
Back = 39 x 14 3/4
Shared Port Internal Assembly Parts:
2 x Front to Back = 15 3/8 x 14 3/4
2 x Extension = 6 15/16 x 14 3/4
Assembly guide (generic dimensions):
I smell troll
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
could post pics of the car, as i have never heard of a steeda edition ford focus except for the new gen focus.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
