Nate Futuristic Posted November 14, 2012 Report Posted November 14, 2012 9 down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
alaskanzx5 Posted November 14, 2012 Report Posted November 14, 2012 ok, i will ask the question. ported yes or no? if yes what do you want it tuned to? max dimensions you are willing to use? ( from 2000-2007 im fairly certian are the same. meaning that a simple box max dimension would be 39wide 18 deep 18-19tall) what kind of power are you running to them? do you want them sub up port back, sub and port up, sub back port up? or anyother specific way? last but not least, did you even try to read anything on this forum that could help teach you how to design a box yourself? if not go do it and we will be able to tell if you did or not by you answering the questions. including this next one when building a box for a sub rated at 1000watts rms but giving it 1500watts rms should the box be bigger or smaller? should the port be bigger or smaller? t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
zack_e89 Posted November 14, 2012 Report Posted November 14, 2012 9 9.1* 97 Suburban 8 custom PSI Platform 3 18's
focas23 Posted November 14, 2012 Author Report Posted November 14, 2012 Well from what I know the more power the smaller the box but I'm a painter
Joe X Posted November 14, 2012 Report Posted November 14, 2012 Well from what I know the more power the smaller the box but I'm a painter Get the maximum dimensions of the box you can fit in your vehicle and the model of the amp you are going to use with those subs.
focas23 Posted November 15, 2012 Author Report Posted November 15, 2012 Well from what I know the more power the smaller the box but I'm a painter
Noel989 Posted November 15, 2012 Report Posted November 15, 2012 This guy trying to troll but not funny Build Log - http://www.stevemead...-cruiser-el-pt/
