revoracing247 Posted November 14, 2012 Report Posted November 14, 2012 hey guys quick question about painting my box. so already i've done 4-5 coats of primer and sanded with 100 grit up to 220 grit. now i've just put on 4-5 goats of gloss white paint on last night and i just wet sanded with 600 grit. and looking at itm it's not as glossy/reflective as i thought it'd be at this stage. i've never done this before so im not exactly sure what it should look like. so im wondering if it not being really shiny or glossy after doing the 4-5 coats of color on there is normal or not. or if all that glossy really reflective look comes from when i put on the clear coat on there. basically wondering if i should move on to clear coat right now or go back and put several more coats of white gloss color on there. if you know that's be great! thanks! ~ If it was easy, everybody would be doing it ~
revoracing247 Posted November 14, 2012 Author Report Posted November 14, 2012 does anyone have any suggestions? i know it's a little hard to tell with no pics but it's hard to take pics like this with my phone in some spots it's almost opaque :/ ~ If it was easy, everybody would be doing it ~
michigancapri92 Posted November 14, 2012 Report Posted November 14, 2012 After you sand you need one more coat ... that low of grit takes the gloss out Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
HunterJohnson Posted November 14, 2012 Report Posted November 14, 2012 Takes some skill to paint without orange peel. Go slower than fast making sure it's an even coat and then sand after 1200 grit wet then clear coat it a few times same technique then polish it Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
michigancapri92 Posted November 14, 2012 Report Posted November 14, 2012 The clear coat should also give you the gloss Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
revoracing247 Posted November 14, 2012 Author Report Posted November 14, 2012 do i need to wait for it to dry completely to sand again with a higher grit before i start putting clear on? or can i put a couple coats of white gloss and then go into clear? and thanks for responding! i just have everything set up and ready to go in the garage (gotta heat it all up above 50 degrees) ~ If it was easy, everybody would be doing it ~
josueh95 Posted November 14, 2012 Report Posted November 14, 2012 i would add one more coat and then sand with 1000 grit..it will look dull again but make sure it is smooth..add 2-3 coats of clear and wetsand with 2000 grit. once your done apply a rubbing compound and that glossy shine will come right out -2000 chevy tahoe 5.3 liter v8 -two DC audio level 3 15 inch subwoofers -2 pairs of infinity kappa 60.9cs components -rockford fosgate t1500.1bd for subs -rockford fosgate t400.4bd for mids and highs -alpine deck -big 3 upgrade 0 gauge power cable -optima yellow top battery -custom made subwoofer enclosure 6 cubic feet tuned at 35hz
mbdblue Posted November 14, 2012 Report Posted November 14, 2012 you color coat shouldn't need to be sanded man. Just needs coverage, then the clear coat. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
revoracing247 Posted November 14, 2012 Author Report Posted November 14, 2012 Takes some skill to paint without orange peel. Go slower than fast making sure it's an even coat and then sand after 1200 grit wet then clear coat it a few times same technique then polish it i've been trying to take my time on this. im mostly worried about it being really glossy/reflective. and so i should put another couple layers of gloss on and wet sand with 1500 (i don't have 1200) and then put clear on? also if it says dries in an hour and handles in 24. does that mean i can sand in an hour or should i wait till tomorrow? ~ If it was easy, everybody would be doing it ~
revoracing247 Posted November 14, 2012 Author Report Posted November 14, 2012 thanks for your responses! OK, so i should put on a coat or two of color and then go into the clear and then wet sand with 1500 grit and then i'll do the buffing and what not. sounds about right? ~ If it was easy, everybody would be doing it ~
