my car wont stay idled
if you haven't done a compression yet, how do you know its an exhaust valve that's the problem?
And that would be found out by doing a cylinder leak down test which since you haven't done the compression test yet, not sure how you came to that conclusion. The leak down is done almost like the compression test..
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
If you are getting any kind of significant voltage drop it could negatively affect anything electrical. My first check in this situation would be the fuel pump then filter the. Fuel lines etc. sounds like the same problem I had with my wife's 06 explorer ended up being a pinched fuel line.
no i havent came to any conclusions yet thats just what im thinking, think its cylinder 1, thats having the problems.. and i think its the exhaust valve because of what im reading and kandi i dont no if its the exhaust valves yet, and duck i think so but not sure thats why monday im going to take the car to my mechanic and talk to him about it and tell him what its doing, and get a estimate on how much it will cost to fix, thats if i dont need an entire valve job, or i can just replace the couple valves that are screwed up, but if its going to be alot of money then i may just save that money and just drop another motor in and be done with it lol
i havent came to any conclusions yet thats just what im thinking it is, due to looking at tons of topics on it and m car is having the same symptoms
Well when you say when you brake it idles down and dies it makes me think brake booster leak but seems more than that with the revving.
E34 540iT/6
yep and when i just let it idle it gets really low and then the idle jumps up to i guess catch it before it dies and goes up to when the radiator fan comes on to
LOL, pretty sure it has to do with that misfire esp if you have been driving it and gonna assume you know that driving with a misfire will fuck up the cat.
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
yep i was planning on replacing the cat anyways lol.. and here in oklahoma we dont have Smog rules so we dont need cats on our cars
Wait, is this only at idle? If that is the case has anyone suggest cleaning the Idle air control valve. You will ave to take it off and use throttle body cleaner and a rag, and maybe some compressed air. Just a thought.
first thing i did when i got the car, but whenever i can find my mechanic lol, do a compression test, bc i dont have a knocking piston or anything and running on 3 cylinders, plus that spark plug being wet hmmm
