HunterJohnson Posted November 17, 2012 Report Share Posted November 17, 2012 I'm having a brain fart... Ok so I have 3 Subs 2 are D4's and 1 is a D2 What would my impedance be wired all together in series and parallel or how ever you would recommend wiring. Yes HAVE to use all 3 Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
HunterJohnson Posted November 17, 2012 Author Report Share Posted November 17, 2012 Hmm wire the D4's in parallel so 1 ohm. then D2 in parallel at 1 ohm divided by 2 and you're at .5 ohms right? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
HunterJohnson Posted November 17, 2012 Author Report Share Posted November 17, 2012 or run the D4's in series at 4 ohms.. then D2 in series at 4 end up at 2 ohms? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
audiofanaticz Posted November 17, 2012 Report Share Posted November 17, 2012 no use the pair, or the single... you dont mix different impedance woofers, 3500 posts you should know that by now. The single d2 woofer wired at 1 ohm is going to get more power than the pair of d4 woofers wired at 1 ohm. Link to comment Share on other sites More sharing options...
HunterJohnson Posted November 17, 2012 Author Report Share Posted November 17, 2012 no use the pair, or the single... you dont mix different impedance woofers, 3500 posts you should know that by now. The single d2 woofer wired at 1 ohm is going to get more power than the pair of d4 woofers wired at 1 ohm. kk that makes sense. I post what I know and ask what I dont look at my join date I'm still fairly new Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
Noel989 Posted November 17, 2012 Report Share Posted November 17, 2012 They both look correct wire them all and check it with a meter to see the final impedance Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
HunterJohnson Posted November 17, 2012 Author Report Share Posted November 17, 2012 They both look correct wire them all and check it with a meter to see the final impedance thats what I thought but what the other guy said makes sense. since the pair is wired at 1ohm they will see the same power as the single d2 wired at 1 ohm basically the d2 will see twice the power since its all by itself Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
Noel989 Posted November 17, 2012 Report Share Posted November 17, 2012 Yup I was gonna said not to put them in the same box same amp but since you said very clearly " yes I have to use all 3" I thought well If that's what the customer wants then he gets what he wants Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
HunterJohnson Posted November 17, 2012 Author Report Share Posted November 17, 2012 Yup I was gonna said not to put them in the same box same amp but since you said very clearly " yes I have to use all 3" I thought well If that's what the customer wants then he gets what he wants lol nah just a friend asking if he could run then all Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
MrSkippyJ Posted November 17, 2012 Report Share Posted November 17, 2012 Yup I was gonna said not to put them in the same box same amp but since you said very clearly " yes I have to use all 3" I thought well If that's what the customer wants then he gets what he wants Or educate the customer. That a crazy thought, I know. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
