2 or 4 channel amp for front stage?
DynastyDesigns
if your running active you dont use the passive crossover that comes with a component set. instead you have to have a sound processor or cd player that has a built in crossover or an amp that you can set up the freq range for the speakers but im not sure of any amps with the ability to do that as well as what i would want.
And don´t forget you need a 6 channel amp. One of the better ones not the dirt cheap.
The reason to run active is, that you get the best soundquality, but not with a cheap amp, active has his price.
Think there is nothing real fine amp and comps, for together 700 and up.
why would you need a 6 channel amp?
im gonna do an active setup using a pioneer deh 80prs a t400.4 2 punch pro tweets 2 punch pro 6.5 a t1500.1bdcp and 2 t2d415.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
http://www.ebay.com/itm/300-2-BLACK-JL-AUDIO-AMP-2-CH-600W-MAX-SUB-SUBWOOFER-SPEAKER-AMPLIFIER-RARE-/120916599527?pt=Car_Amplifiers&hash=item1c2730e2e7&vxp=mtr The JL amp is a 2 channel amp, that means run a passive component system, from best till highest quality 150 watt RMS on
a comp set is alot, or if you want you can place 2 comp set´s in the door´s or the rear. Door´s or rear incase you cant ajust the soundlevle´s with a 2 channel amp.
If you want to run active you need 2 of those amp´s for a comp-set of speakers. It´s not possible to run the channels diffrent to fire 4 speakers active.
You have only to channel´s you can put there the midbass or the Tweet´s but not together.
From the kind of questions you ask, i guess you to stay away from active. It´s not easy to set a active crossover, if you do, have a look and maby you find someone
with a CC-1 (absolute most have a DD 1 as well if they have a CC-1) http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/ who can
help you to set your X-over correct. And here a link for a nice-priced 2. 2-channel (think best for tweet´s) http://www.ebay.com./itm/261120445289?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649.
And dont forget to create a build-log with a lot of pics.
"in the abundance of water, the fool is thirsty" Bob Marley
3-way compset 6 channel´s, 2-way compset 4 channel´s.
ok i see what you where saying there. just confused me as im learning the whole active thing as i go. lmao, most likely not the best way to learn for running active but im sure ill get it figured out with out going through mids and highs.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
If you start out with a passive 2 way component set on a 2 channel amp (like I suggested on post #5), you can always test and tune and then upgrade ...
Just like buying a starter train set as a kid ... you either leave it like it is and enjoy it, or you add to it to make it better with experience, or you hit the books and upgrade to better, more experienced setups ...
For the most part, depends on testing, tuning, installation preference and skills, and exactly how far you want to go with the setup (budget) ...
