Interchangeable Port Question
SlamminBeats
When you add an external port in Torres, you need to change the port length to the length of the entire port. So add the length of the internal port to the external and plug that in. Then put the external port length into the external port length box.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
What u said op won't work you are just closing the opening of the port down. You have to change the entire port not just the mouth.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
wouldnt making the port smaller in that matter also affect the box volume since the port walls would be thicker?
this is what he was talking about
the external piece is bolted on using t nuts. take the bolts out, remove the external portion of the port then but the bolts back in so you have no air holes.
in the above design the box is tuned at about 40hz (dont remember exactly) then with the external piece added on it drops the tuning down to 35hz. it the next box im gonna build.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
^^^No the net stays the same.
Remember your net volume & port volume are 2 seperate things.
If you reduce the port area by putting layers of wood inside the port, you are eating up port volume, not net.
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
i was literally just about to ask this question. Makes sense to me. I will make an entire insert then.
true but when doing a box design you have to calculate the port wall thickness into the displacement. since the added wood would be on the inside of the port would be the difference there though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
The port air volume plus it's wood is subtracted from the gross to get your net (along with bracing & displacements).
If you add wood to the inside of the port you take away port airspace.
If you add wood to the outside of the port you take away net airspace. <----That's not we're talking about.
Yes, the port thickness matters in Torres when designing a new box...because it grows outwards.
With an existing box and port, we are effectively making it grow inwards.
That does not use any net volume, it takes away port volume.
Buncha OFC Knu
Buncha Second Skin
  • Who's Online   0 Members, 0 Anonymous, 3081 Guests (See full list)
