appealingrelic Posted November 24, 2012 Report Share Posted November 24, 2012 so its odd and probably pointless but has anyone ever seen or heard of making a half ported half sealed box. like run a high qts 10 in the sealed side on an amp with the crossover set higher freq. and a low qts 12 on a separate amp with the crossover set lower? Link to comment Share on other sites More sharing options...
K_SubieXT Posted November 24, 2012 Report Share Posted November 24, 2012 I think pwk designs did a box for a 10 and 12 I think except both sides were ported and idk about the tuning My 95 Jeep Cherokee Build: http://www.stevemeadedesigns.com/board/topic/157643-1995-jeep-cherokee-build-sub-is-in-and-playing/ Link to comment Share on other sites More sharing options...
will77530 Posted November 24, 2012 Report Share Posted November 24, 2012 techforce had a box with fifteens and eighteens that were both ported at different frequencies same concept as what your talking about Link to comment Share on other sites More sharing options...
SnowDrifter Posted November 24, 2012 Report Share Posted November 24, 2012 Interesting idea, but why? You would essentially be making a box large enough to hold two subs, but only having the power output of 1. And if you were to run both of them at the same time, you would get cancellation. Think about phasing in a ported box vs. sealed box: it will cancel at some frequencies, and boost at others. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Joe X Posted November 24, 2012 Report Share Posted November 24, 2012 so its odd and probably pointless but has anyone ever seen or heard of making a half ported half sealed box. like run a high qts 10 in the sealed side on an amp with the crossover set higher freq. and a low qts 12 on a separate amp with the crossover set lower? A couple of ideas like that have been posted on here, I remember the comments of one guy doing this saying that his ported box wouldn't blend in well with the front stage like his sealed did but sealed lacked low end. I think that ported alone can do well as long as it's setup right. Link to comment Share on other sites More sharing options...
appealingrelic Posted November 24, 2012 Author Report Share Posted November 24, 2012 I thought about cancellation but don't have a perfect grasp on the concept of how waves behave in different setups but I had the idea of setting crossovers to have each sub playing different frequencies. Kind of a sound quality concept of sorts. Plus it'd be a unique showpiece if it worked properly. Link to comment Share on other sites More sharing options...
