whotry Posted November 28, 2012 Report Share Posted November 28, 2012 Hello everyone, I just picked up 2 12 L7s 2 ohm dvc and Im in help of building my first box. I have a 2nd generation Lexus GS300. Im a noob to this but would love to build my own box. My trunk dimensions are Max Height = 15 Max Width=65.5 Max Depth = 10 I was planning to tune it around 33 Hz with one or two ports, if someone can help me out with calculating everything I would greatly appreciate it. Link to comment Share on other sites More sharing options...
Truconcept Posted November 28, 2012 Report Share Posted November 28, 2012 try using torres box calculator **actin bad like a kid at six flags** Link to comment Share on other sites More sharing options...
Joe X Posted November 28, 2012 Report Share Posted November 28, 2012 Hello everyone, I just picked up 2 12 L7s 2 ohm dvc and Im in help of building my first box. I have a 2nd generation Lexus GS300. Im a noob to this but would love to build my own box. My trunk dimensions are Max Height = 15 Max Width=65.5 Max Depth = 10 I was planning to tune it around 33 Hz with one or two ports, if someone can help me out with calculating everything I would greatly appreciate it. You would need to have like 15" deep, also even if you have that width I am not sure you would be able to fit it in it's way in. Link to comment Share on other sites More sharing options...
whotry Posted November 28, 2012 Author Report Share Posted November 28, 2012 I have enough more depth to add but idk if it will work my trunk is weird it has a small opening in the back then opens to a larger opening would I be able to build a box to fit the small opening and expand it ? Here's a picture of the trunk. Link to comment Share on other sites More sharing options...
whotry Posted November 28, 2012 Author Report Share Posted November 28, 2012 http://i8.photobucket.com/albums/a11/mobster909/Installs%20-%20cars%20-%20audio/Lexus%20GS300/DSC03642.jpg Link to comment Share on other sites More sharing options...
Guest Posted November 28, 2012 Report Share Posted November 28, 2012 you'd probably want like 4-5 cubes after displacements. Link to comment Share on other sites More sharing options...
Joe X Posted November 28, 2012 Report Share Posted November 28, 2012 The method I usually suggest is to build a cardboard dummy box the size you think it can still fit. but anyways, the box can be made not as wide and a little deeper or even taller depending on what you have. Link to comment Share on other sites More sharing options...
whotry Posted November 28, 2012 Author Report Share Posted November 28, 2012 Can someone use Torres to spec a box to 5 cubes I work graveyard shift so I have no computer access Link to comment Share on other sites More sharing options...
john253a Posted November 29, 2012 Report Share Posted November 29, 2012 i ran a single L7 in 7net 90sqin of port on 1k for a while and loved it dont tune them low is all i can say and with the measurements you've given don't even have enough room for ONE L7 let alown 2 just for ONE L7 youll need a box of 65x16x15 to get 6net with 87sq" port 35-37hz if you can get 65x16x27" deep you can run 2 @35-37hz with 170-180sq" of port and have 10net but idd per 30"deep to give you 12net Link to comment Share on other sites More sharing options...
Joe X Posted November 29, 2012 Report Share Posted November 29, 2012 Can someone use Torres to spec a box to 5 cubes I work graveyard shift so I have no computer access I can do it just tell me what dimensions you can fit in the way into your trunk. Im sure it will be less than 65" Link to comment Share on other sites More sharing options...
