OrzechNJ Posted November 28, 2012 Report Share Posted November 28, 2012 Whats up guys Since yesterday i run two sets of RF t2652s in my front door , active with my hu front for tweeters rear for mids and low for sub .. I was playin around with the crossovers and eq but im not sure about the crossovers i know that all aplocations are different but how i supposed to set the crossovers for mids and highs to get a max from it before using the auto eq? And should i set the possition for tome allignment ? The amp is on hp for twt and all pass for mids.. Sorry guys for too much reading but i just wanna explain it best ican Edit t600-4 amp sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted November 28, 2012 Report Share Posted November 28, 2012 use the recommended (by RF) frequencies for the crossovers. no need to use the crossovers on the amp if you are using the ones in the HU. Use time alignment to make it sound good to your ears. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
OrzechNJ Posted November 29, 2012 Author Report Share Posted November 29, 2012 My current crossover setup Lpf 63hz slope 12 Mid hpf 125hz slope 12 Mid lpf 3.15khz slope 12 High hpf 6.3khz slope 18 sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted November 29, 2012 Report Share Posted November 29, 2012 i would recommend lowering your tweets hpf to something closer to 3k F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
SWIFT Posted November 29, 2012 Report Share Posted November 29, 2012 My current crossover setup Lpf 63hz slope 12 Mid hpf 125hz slope 12 Mid lpf 3.15khz slope 12 High hpf 6.3khz slope 18 You have big gaps there. Try LPF 80hz 24db slope Mid HPF 80hz 24db slope Mid LPF 4khz 24db slope High HPF 4khz 18db slope 2012 F250 Lariat 6.7, lifted on 22's and 35's 4 DSS Ethos 18's walled tuned low 2 Ampere Audio 7500.1's, Ampere 125.4 Rockford Pro Audio front stage 9 batteries, Mechman Elite 370 alt Team DSS, Team Ampere Audio 2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals Link to comment Share on other sites More sharing options...
OrzechNJ Posted November 29, 2012 Author Report Share Posted November 29, 2012 ok I will try it tomorrow... thats how i set the other set of t2s and I know that all aplications is different but thats how my eq looks so far .. I was looking in to this thread http://www.stevemeadedesigns.com/board/topic/4319-sq-how-to-tune-your-system-a-must-read/ and I think its best I got so far sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over. Link to comment Share on other sites More sharing options...
tacomaguy1 Posted November 29, 2012 Report Share Posted November 29, 2012 That is.probably the worst tweeter location Team Flex Issues Link to comment Share on other sites More sharing options...
OrzechNJ Posted November 29, 2012 Author Report Share Posted November 29, 2012 That is.probably the worst tweeter location yea I figured it out .. but it still does the job.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over. Link to comment Share on other sites More sharing options...
OrzechNJ Posted November 29, 2012 Author Report Share Posted November 29, 2012 I wanna put another set under the windshield later but Im good with this spot for now . sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted November 29, 2012 Report Share Posted November 29, 2012 I would rework the doors first and redo some of the placements before I would try to start adding speakers. I have 2 T1652s 6.5s in each door and a single T1 tweet in each door. it really does the trick. You are going to run into more problems than you fix if you just keep adding speakers! F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
