Sufficient Power
My next build is gonna be awhile off, but since I didn't take the time to do my research and planning last time I thought I might try to do it once and be done this time. Now I come to the most commonly asked question, is this enough power for my application?
Wattage: ~8-10k
Electrical plans:
- Iraggi 380amp alt
- D1400 up front
- 4 D3400s in the back
- Big 3 in 1/0
- 8 runs of 1/0 from front to back, 4 positive/4 negative, one to each D3400
- 4 1/0 frame grounds in back
Am I missing anything? Should this cover it? What else would/should I need?
Lane AKA HeroKight
'96 Jeep Cherokee Classic 4x4
R.I.P. Molliboo
$200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands?
You hear that????
That's a category 5 shit storm coming
n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads.
^^^Rules. Follow them.^^^
Probably. I figured that might be a little small. I would check XS Power's site, but the vehicle guide won't pull up for some reason.
Lane AKA HeroKight
R.I.P. Molliboo
You hear that????
Do you realize the d1400 is a 14v battery and its basically the same dimensions as the d3400. I'd try.to run 2 alts if your goal is 10kish .
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Shit I was trying to figure out why it wasn't showing up where I was looking on their website. I'm wanting to run 1 C1100.4, 2 C1600.2, and 1 BC5500. They're supposed to put out around 8k all together at 13.8, so I figured if I had higher voltage they might put out a little more. That's why I said 8-10kw. It would be my daily driver system.
Lane AKA HeroKight
R.I.P. Molliboo
You hear that????
  • Who's Online   0 Members, 0 Anonymous, 1619 Guests (See full list)
