Loud & Low 8th Gen Civic - Time to say good bye to her.
Ok so here's the deal. After thinking about it, I decided to just post up what I did last night. I'm pretty happy with it, and I know I didn't come up with it, but I was able to figure out for the most part how to make it work etc. Saves me some money cause frankly I didn't have the money to buy the one that's out there. The only money it cost me was for the fan control, and the temperature gauge. So about $18.00. Everything else in here I had laying around. So at the end of the day, if there's an issue, I'll go ahead and delete this, but for now I'm going to just let it fly. Here goes!
First I got some parts (pictured above but I wanted to keep this all together):
Nice little ebay temperature gauge - $7.50
Then I got a PT021 Adjustable Fan Control Switch (90 - 130 Degrees) from ebay - $9.99
Then I got out the rest of the stuff. This is all the stuff I had laying around:
Multiple colors of Primary wire
Stinger fan
Barrier strip
Spade connectors
Fork connectors
Relay
Switch
Plank of wood
Screws
Tools: wire strippers, cutters, screwdriver, crimpers
and my instructions that I wrote and drew out.
Got everything set up in an ordered manner on the plank of wood. Added another strip to allow the fan to attach to something, and it actually worked out there really well. You can see the order of the components from upper left to right, relay, temperature gauge, fan; lower left to right, switch, barrier strip, fan control.
Then took my time and wired it up. Looks a little messy cause of the coiled up temperature gauge wire I put under the other wires in the back. But I think you get the idea.
Wire colors go like this:
Orange - From pin 30 on the relay - out to the fan/s
Green - Ignition wire (from switch) - to pin 86 on relay (needs a diode between it and pin 85)- to temperature gauge
Yellow - 12v constant power source (battery - NEEDS FUSE) - to pin 87 on relay
Purple - From pin 85 on the relay (needs a diode between it and pin 86) - to fan control switch
Black - Ground
So in this case the green and yellow go on the battery positive because I'm using the switch to act as my ignition on the test model here.
The switch
The fan and fan control switch
Next I'll run through what happens!
First we turn on the ignition source, the switch here
We have power, except my temperature gauge doesn't work right. What do you expect from ebay I guess! I'll have another one before the final product.
Now then, we have power everything is ready to go. You're pushing your system kind of hard, your amps are heating up (here I'm using a heat gun to simulate that. YES its a cheap one but I couldn't find my good one.) The control switch is going to sit near the amps where it's going to get the most heat. You set your temperature where you want it, by the way what is a good temperature to set this at for your amps? Where do your amps best perform where they're not too hot? Anyone have any suggestions? Really asking!
So you see in the background there, the fan is off. The heat gun is now going, you can see the orange light thats on at the tip.
Once the temperature gets to your set point, whatever you want that to be, then the fan control switch closes and sends a signal to the relay. Then it goes through the relay and switches on, in the video you might hear it click, in real life close up you will hear it click. The signal then gets sent through the orange wire and turns the fan on. You can see that here in the background.
After that, it will stay on until the temperature goes below that set point, I think about 5 or 10 degrees. Then it will open the control switch and thus switching the relay off, thus turning the fans off. Here I put the fan control switch in front of the fan to cool it and turn it off sooner.
So the only things missing in this test set up are these:
1 - Diode between pins 85 and 86 - this stops back current (i believe) when the relay is shut off.
2 - Fuse on the power wire, for obvious reasons
3 - Bigger gauged power wire.
I'm going to condense all this and put it in a project box. If you don't know what those are, they're small boxes, actually they come in all sizes, and you normally use them for small circuit boars or battery holders or stuff like that. You can find them at fry's and probably radio shack. I have this all spread out so it would be easy to see and figure out. Once I get it all condensed into a little box, it'll make it much more compact and easy to install. I'll show it when I get done with it.
Here's a video explaining all that I just went through up above. Enjoy.
Again, as I said before I don't want to piss anyone off, or step on any toes. But this was made on some looking and figuring out on a model that was on the internet and on here and there was a video of it done kind of explaining it. I'm not here to take money out of anyone's pocket or anything like that, and if it comes back that this is wrong by their standards I'll happily delete these last two posts. I'm NOT an electronics expert, or anything even remotely close. I'm just a hobbiest, who liked what he saw, and decided I could try and make it and save my self some money. It worked, and that's why I'm posting it. That's my disclaimer! Thanks!
I'll post the finished product when I get it done!
Now then let's move on. I made a little progress on the tablet. Not a bunch but I got it sanded down, I think that's where I left off last time. I threw some primer on it, found there were some pinholes in the side walls. I also found that there was a rather large dip in the center of the back panel. I built the sides up I guess and didn't think about the middle. That's why i had the gap in the middle when the tablet was in. So I fixed that by getting a piece of scrap ply that was straight, from when I made the strips for the enclosure, and spread some filler with that. Then I added some to the top. That should allow me to sand it to a nice straight finish.
This is how she sits tonight!
Tomorrow I'l sand it out, and then primer it again, and most likely put the front on and start working that!
That's it for tonight folks! Thanks for checking in!
that tablet panel just keeps looking better and better you do some amazing work my friend
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
Thanks guys.
Hoping to get that tablet panel completely done today. Or very very close anyway. Then I'll move onto other things. Probably onto the head unit install next. Trying to get that dash piece out, and if not that, then figuring out how to deal without taking it out. More to come throughout the day guys!
Damn. Looking good man. That's a pretty ingenious way to cool your amps.
Lane AKA HeroKight
'96 Jeep Cherokee Classic 4x4
R.I.P. Molliboo
$200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands?
You hear that????
That's a category 5 shit storm coming
n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads.
^^^Rules. Follow them.^^^
Ok so here's today's progress thus far.
Got the rest sanded down and was pleased with it.
Much much better on the seam there between the bezel and the tablet. I'm holding the tablet with my finger on the far side that's why it looks closer there and not on the other side. But it's very close so I'm happy with it.
So then I was trying to decide what I wanted to do with it to give it a kind of grippy back and not put suede or something in there. PLASTIDIP to the rescue!
Ready to spray
Now after that I had a bit of a set back. I tried to take a picture of it but it didn't come out. It's cold and rainy here in Sac today. So as I've said before I pretty much only have my covered side of the house to work in. SO since it was cold I used a shop light to speed up the curing process on the plastidip. Well I must have left it on there too long cause the epoxy let go a bit and the spot where the back panel meets the dock. But after bringing it in and working on it a bit, and then the epoxy cooling, it has set again and is solid again. There isn't much of a line there at all anymore. I thought about re spraying it, but then looked and the front frame is going to cover it and it won't be seen at all. So I'm just going to let it be.
The tablet sits on there nicely and doesn't move around like before when it was just the filler etc. So I'm happy with it thus far.
So speaking of the front frame, I went ahead and plastidipped the back side of that as well. Now the whole inside cubby of the tablet holder is plastidipped.
Set the timer on this one. LOL
I just put the second coat on and when that's dry, I'll go put it on the main piece. So that's it for now. More later!
So I have more progress. I guess though, if no one is interested in pictures, I'll just save them from here on out.
So here's the finished front piece. This is the inside
and outside
Next I had to protect my investment!
Time to take the next step. Dash piece, taped up tablet, epoxy, front piece, and a christmas piece I had to fix!
Starting to take shape!
Couldn't help myself! I got real excited here!
Then I decided to reinforce the sides
So, now that's drying, and I'll give it an hour or so to really dry. In the meantime I'm going to go have some lunch, fold some laundry, and then I'll see about getting some filler on it. I'm trying to decide if I want to fill the sides so it tapers down, or leave it as a step down the way it is but just clean it up. I think i want to taper it. I think it'll look a lot better then the step down.
So that's it for now. I guess I'll stop posting pics today since no one seems interested!
