help designing a box
johnnyboy
Its high on the port volume and you need a double baffle and some bracing would help
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
In case this is for a trunk car:
Enclosure Specifications:
Fb = 40 Hz
Vb = 4.5 ft^3
External Height = 17 in
External Width = 36 in
External Depth = 24 in
Port Width = 6 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 36 x 17
Left & Right Sides = 21 3/4 x 15 1/2
Top & Bottom = 36 x 21 3/4
L Port Internal Assembly Parts:
Front to Back = 15 1/4 x 15 1/2
Extension = 2 x 15 1/2
Dimensions must fit in the way in, 6" of free airspace in front of the port. If this is for a non trunk car it must be changed.
Thanks Joe and yes it for the trunk of the car, but i want it tuned a bit higher, my question is am i giving it adequate port area an net volume?
The net volume I used is recommended by them, I think that up to rated power it's ok to use that, changed the tuning but using a tuning that high will require to set your subsonic filter high as well, like 35Hz or so.
  • Who's Online   0 Members, 0 Anonymous, 1337 Guests (See full list)
