Possible to do a Hair trick with a single 15?
his box would not be the same as yours. it just doesnt work that way my man.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Yea your right, I just wanted people in here to know it is possible to get a good hair trick from one 15 in a trunk build....In a regular truck cab it would be easy lol. My build is more about efficiency then anything.....
149.4 Db @ 30Hz Outlaw With One 15" Fi Team Sub, Trunk Build. !!!!!Hair Tricks!!!!!
Check Out The Build Log http://www.stevemead...0-4-and-t400-4/
Watch The Videos http://www.youtube.com/user/jcplaya3
Me and my friend did one with his Singlw 12 BTL today. its possible
Could you share enclosure details and how much power you were running?
I forget dimensions but it was around 3.7 cu ft. 30 hz. It was in a toyota tacoma with port loading off of door. He had quite a bit of port area too. it was on right at 2k. Wasnt a big one but it was noticeable
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Yea its easy when your like 2 feet away from the sub in a cab.....try the trunk lol
you need to have an atleast 80% deadened and sealed vehicle for just one 15 ,the less cabin area you give your subwoofer(sealed off from trunk),the more potential it has to move air. Once that's done,you can start playing with power,port area,cabin gain & enclosure size. It honestly makes things much easier if you deaden & seal your car first. Then comes trial & error. I can nearly get my 15 nigtshade to move air,maily because of my 18sq inch per cu.ft @ 40hz with a net of 2.2 and port vol near 1cu.ft. aslo a crappy brz1700.
Next build consist of 7 cubes gross ,2 cu.ft of port volume at 30hz,forward firing & a rubi2500. Hopefully I will be able to pull a small trick from my trunk setup
  • 8 months later...
  • Who's Online   2 Members, 0 Anonymous, 1230 Guests (See full list)
