RodeoSport Posted December 3, 2012 Report Posted December 3, 2012 Hi I was wondering if it is possible to move enough air with a single 15inch Fi N2 BTL? Are Band-pass enclosures better or ported? It will be going in a mid size SUV and can give it around 4Kw of power. Thanks
tacomaguy1 Posted December 3, 2012 Report Posted December 3, 2012 yes, it won't be a huge one but if the enclosure is done properly it should move some air Team Flex Issues
the_garynator Posted December 3, 2012 Report Posted December 3, 2012 it's possible, but you'd probably have to do a lot of testing. Hair tricks (anything more than just a little hair flopping around, i.e. what you see in videos) on a single 15 isn't easy. Current Build: Project Flexington: 157.6db @ 37hz Parallel 6th order walk through, DC Neo Elite 18s, 4 DC 5.0ks, JY Lithium, 12 banks of XS Caps Old Builds:150db and HAIRTRICKs from 2x 12" Power Acoustik Mofos (6th order blow through) ;<p>Roadmaster Wagon Build - DC LVL 6 M3, Kicker Warhorse ; Godzilla swapped 240sx ; 6th Order Bandpass Alpine Type R 12 ; Fully loaded DC Level 5 18" 240sx
alaskanzx5 Posted December 3, 2012 Report Posted December 3, 2012 you posted this in the ground pounding section, how is a small hair trick with a single 15 a ground pounder? t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
RodeoSport Posted December 3, 2012 Author Report Posted December 3, 2012 you posted this in the ground pounding section, how is a small hair trick with a single 15 a ground pounder? Im sorry, I had more than one tab when i created the thread. Mods could you please move this to the appropriate section. it's possible, but you'd probably have to do a lot of testing. Hair tricks (anything more than just a little hair flopping around, i.e. what you see in videos) on a single 15 isn't easy. Yeah I realized i wouldnt be able to do anything crazy like in all the videos on youtube.... Do you feel a Ported or Bandpass enclosure would be better?
FosgateLife Posted December 3, 2012 Report Posted December 3, 2012 Me and my friend did one with his Singlw 12 BTL today. its possible 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
the_garynator Posted December 3, 2012 Report Posted December 3, 2012 it's possible, but you'd probably have to do a lot of testing. Hair tricks (anything more than just a little hair flopping around, i.e. what you see in videos) on a single 15 isn't easy. Yeah I realized i wouldnt be able to do anything crazy like in all the videos on youtube.... Do you feel a Ported or Bandpass enclosure would be better? I'd do ported personally. I was able to get a small hair trick off of my 15" M1 Level 5 on an AP30001D in a box tuned to about 36hz...it was by no means anything impressive, but I have seen a couple of decent hair tricks off of similar cone surface area, but those builds have a lot of time into them. It would be a lot easier if you ran 2 15s or 2 18s though. Current Build: Project Flexington: 157.6db @ 37hz Parallel 6th order walk through, DC Neo Elite 18s, 4 DC 5.0ks, JY Lithium, 12 banks of XS Caps Old Builds:150db and HAIRTRICKs from 2x 12" Power Acoustik Mofos (6th order blow through) ;<p>Roadmaster Wagon Build - DC LVL 6 M3, Kicker Warhorse ; Godzilla swapped 240sx ; 6th Order Bandpass Alpine Type R 12 ; Fully loaded DC Level 5 18" 240sx
rocking.that.eclipse Posted December 3, 2012 Report Posted December 3, 2012 If i remember right he did it with a single sp4 15 also
RodeoSport Posted December 3, 2012 Author Report Posted December 3, 2012 it's possible, but you'd probably have to do a lot of testing. Hair tricks (anything more than just a little hair flopping around, i.e. what you see in videos) on a single 15 isn't easy. Yeah I realized i wouldnt be able to do anything crazy like in all the videos on youtube.... Do you feel a Ported or Bandpass enclosure would be better? I'd do ported personally. I was able to get a small hair trick off of my 15" M1 Level 5 on an AP30001D in a box tuned to about 36hz...it was by no means anything impressive, but I have seen a couple of decent hair tricks off of similar cone surface area, but those builds have a lot of time into them. It would be a lot easier if you ran 2 15s or 2 18s though. Yeah 2 15s would be nice but they are EXPENSIVE to get shipped to where I am ($600-$800) using fedex. Just got 1 in, will have to wait for a while before I can get another one.
RodeoSport Posted December 5, 2012 Author Report Posted December 5, 2012 Me and my friend did one with his Singlw 12 BTL today. its possible Could you share enclosure details and how much power you were running?
