CortezDTV Posted December 5, 2012 Report Posted December 5, 2012 ^^^^ you know how many times I've said they are wired perfect and ray (dc98hoe) tells me check wiring... sure enough out of phas..... Also a dmm on the speaker leads going into the amp will give you an idea Subs mov differently normally..... when you have a slot port on one side.... Recone one sub and not both would give them different suspentions..... even with the same soft parts they will never perform exactly the same...... But wmrcs please explain how I was wrong! SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
wmrcs Posted December 5, 2012 Report Posted December 5, 2012 ^^^^ you know how many times I've said they are wired perfect and ray (dc98hoe) tells me check wiring... sure enough out of phas..... Also a dmm on the speaker leads going into the amp will give you an idea Subs mov differently normally..... when you have a slot port on one side.... Recone one sub and not both would give them different suspentions..... even with the same soft parts they will never perform exactly the same...... But wmrcs please explain how I was wrong! Okay. One of the earliest posts was Sensai saying to check wiring. edit: oh and subs move the same when the box is symmetrical. E34 540iT/6
Truconcept Posted December 5, 2012 Report Posted December 5, 2012 idk if i missed something but u haven't took ur subs out the box yet 2 see if the wirings all good? i had this happen once it turned out the quieter sub had an input terminal that was little loose causing one of the coils to be actin up tightened up the bolt was good 2 go that was just my experience tho **actin bad like a kid at six flags**
CortezDTV Posted December 5, 2012 Report Posted December 5, 2012 He said he didn't wanna take the subs out I gave him the easiest way to check this without doing any fucking work unhook 2- 4 wires max! Put on battery and bam that would answer all his questions Y does there always gotta be one smartass per thread..... fuck SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
wmrcs Posted December 5, 2012 Report Posted December 5, 2012 He said he didn't wanna take the subs out I gave him the easiest way to check this without doing any fucking work unhook 2- 4 wires max! Put on battery and bam that would answer all his questions Y does there always gotta be one smartass per thread..... fuck loal E34 540iT/6
8ight Posted December 5, 2012 Report Posted December 5, 2012 To see if the woofers are in phase all that needs to be done is a pop test. I'm gonna hate
8ight Posted December 5, 2012 Report Posted December 5, 2012 I don't see the need to make this any harder than it needs to be. I would rather not chase an issue around because I was too lazy to pull subs, I would yank them and see just what is going on. I'm gonna hate
CortezDTV Posted December 5, 2012 Report Posted December 5, 2012 And before you pull them you should see if you even have to.... a pop test...... SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
8ight Posted December 5, 2012 Report Posted December 5, 2012 And before you pull them you should see if you even have to.... a pop test...... Well he will have to either way, to rewire if the test fails or to investigate further if it passes. I'm gonna hate
SlamminBeats Posted December 5, 2012 Author Report Posted December 5, 2012 how can we help you if you wont try what we recommend? hey, STFU i know more diagnosing this then you. I know what needs to be done. Of course i'm going to take them out eventually, its just id rather exhaust every other test first like a normal human being.
