Upgrade PC build -- My list / your thoughts
Well I have been pondering the Idea of building a new PC. My current PC has served me well with no issues.
My Current PC
Intel Core 2 Quad Q6600
Gigabyte EP45-UD3P
8 gig DDR2
ATI Radeon HD4870
My next build I am wanting to keep under $800.00.
I am going to keep some hardware from my current PC such as my power supply which is a PC power and Cooling silencer 610, TV Tuner, Hard drives and DVD burner. My OS drive is a 256gb Samsung SSD 830. I also have a PC Power and Cooling 1000 watt PSU that I have never used because it is to big for my current HTPC case.
So far my list for my new system looks like this.
New Build
$174.99 SAPPHIRE 100355-1GOCL Radeon HD 7850 --> http://www.newegg.com/Product/Product.aspx?Item=N82E16814202004
$ 99.99 COOLER MASTER HAF XB RC-902XB-KKN1 --> http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265
$129.99 g.skill ripjaws z series 16gb (4x 4gb) 2133 --> http://www.newegg.com/Product/Product.aspx?Item=N82E16820231503
$239.99 ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 --> http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
$214.99 Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) --> http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
$859.85
I am thinking that I can probably piece this system together for under $800.00 If I did some more digging for best prices.
I am only interested in Intel based systems. form there I am open to suggestion on different hardware that would be cheaper but perform the same or better... Thanks
That case is so gorgeous... Looks like a perfect build to me :D
Only problem I see with the case is it only has 2 3.5" drive bays. From the pictures though it looks like the 2.5" HD cage is interchangeable with a 3.5" cage or it looks like the is a place to remove that cage and slide in a 3.5 cage.
I have (5) 3.5" Hdd's and the 2.5" SSD
Love the case, but you could go cheaper on the case and mb, and put those dollars into processor / video / memory
If you're feeling DOWN & OUT, it's time to get UP & IN
Does that case have a lot of extra HDD slots?
Edit: Had the page loaded from hours ago, then replied still seeing the old replies, haha
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Honestly, the only thing I see his rig really needing is the graphics, that i5 at 3.4 normal, he can OC that easily over 4.0, 16GB of ram is a lot, he's already got 2 SSD's and a bunch of storage space, the GFX card is the only thing in there that could use a upgrade, to the 7970 o.o
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Well I could cut the case out all together and just rebuild my HTPC case. That extra 100.00 could go into something better. Only issue with my case from experience is everything is packed in there like sardines, not much air flow and that is why I have not overclocked.
That case in my list I think could have excellent air flow. I like how the Motherboard is on top of the drive's and PSU. Wiring that case would be easy and clean with nice airflow across the Motherboard and components with no obstruction of wires. I think it will overclock well.
I went with case because I really dont game much and thought the HD 7850 would be good enough for a PC that mostly is a HTPC. I output to two screens a 24" 1080 x 1200 Monitor and a 60" 1080P TV
I would have to see how much more video card I could get for another 100.00 and cutting the case out.
If i left case out and reused my case I could go with this video care for the same price range.
SAPPHIRE Radeon HD 7950 --> http://www.newegg.co...N82E16814202006
question is is it worth the extra 100.00 to go from 7850 to 7950?
you could get a cheaper CPU and just OC
Any suggestions?
I am all for going cheaper on CPU and OCing to get performance of a better cpu.
