box plans for 3sav.2 8's.....single cab f150
bigmescan
yeah the dodgebtrucks have alot of room.......i believe you have close to 5cbft back there.......
i do envy the dodges, lucky sob's . . .
No way tune 28hz you'll never get it that low 32-33hz would be me
But he'll never get that either within that box shap and design
Idd susgest anything under 40hz that fits with a standard psp port
As for coil config most on a 3 setup would get dual 2 as to get 2000rms at 2.66 is a big amp and cost a bit of coin
Edit
"CS" you'll see I said desired Hz
Just do you
If you notice I had a winky face at the end of the comment, indicating it was only a joke. I'm always a fan if your suggestions and was only giving you crap. I HAVE seen you suggest to baby folks running or wanting to run the SA8 to tune below 30Hz. I know that you personally always like to consider vehicle acoustics as well. Like I said, it was joke a joke, wasn't serious at all.
I sort of guessed that, aren't most of us shit stirs, and never saw the smily face
But the sa8 I've found best at 32-33flat
The 12's are what you thinking of @28hz in 1.8net for a nice sq incloser,
But I normally ask for music prefaces as it helps out a bit
And in a single cab 35-37hz is a good range
Also the port ratio is at 7.?:1
you could do 6x 2" psp port at 12" overall but you'll be running around 42-43flat and will yeald 9.?:1
I know many people happy with a tune that high but not many that like low end bass,
it more for dance and rock people
Edit
When U give some more info ill be able to draw something better
But without knowing side clearance side ported is out and I still need a Topdepth of box
something like this is ok
wow thanks bro...top and bottom can be 7 in. reason being if i tilt the sub at all and try to get it close to the bottom the magnet will hit. i dont know how much that would change........
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
with the 6 5/8" m/deepth your box need to 7 3/8 deep and thats with the mag sitting on back wall if 3/4 mdf is used
can you do 8" top and bottom
or even 8 top and more on bottom like 10 or 11"
what i like to do is get some scrap or cardboard and cut a templet and adjust seat to fit the biggest box possible,
alot of the time you you can go up 2-4" before you angle the box back, giving you more room to work with
if you can to 10" on bottom you can do sub down if you want
after measuring again i need 7 top and 10 bottom but i would need all subs at passenger side and ports on drivers side. with 8 at top its nit ideal for how i drive. and 53 long
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
  • Who's Online   0 Members, 0 Anonymous, 1030 Guests (See full list)
