Just wanted to share some pics of my LS (LQ4) Awesomness.
Some Specs:
2001 LQ4 (Iron LS6) 6.0L Core
Bored .03 over to 4.03
Stroked to 4"
Bore and Stroked to 408 ci. (6.7L)
Weisco 5cc dome pistons
K1 Technolgies Crank (4") and Light Weight Rods
Flowtech Induction 224/288 .612" 112LSA Cam
Stock Rockers With Comp Cams Trunion Upgrade
Patriot Gold .650" Max lift dual springs
Texas Speed Pushrods
3 angle valve job
ARP Main Studs
ARP Head Studs
Edelbrock Pro Flo Intake
Edelbrock 90mm Thrttle Body, Fuel Rails, and 36lb Injectors
The LQ4 when I got it in the garage.
A couple pics from the tare down.
The CORRECT way to remove a crank pulley!
Bare Block
No pics at the moment from when it got back from the machine shop, plus I have soom pics on the camera of some earlier points in the build up that I will try to add in later. For now, some pics from when we were closing it up and a little project I did on the Intake.
Buttoned Up
The intake project
decided I would try to remove the rough sand cast look from the intake. I took about 50 hours of sanding to get it "close" to smoth. Some areas Just wont be seen that well, so they didnt get much attention. Other areas were just imopssible to get to very well so they didn't get as smooth as I wanted, but toward the end, I was just ready to be done. So here is a few pics durring the process.
blade7022-181723-albums-intake-project-2288-picture-smooth-i-had-patence-get-7348.jpg
Spent a few hours polishing the Edlebrock logo on top.
And how it sits, waiting to be dropped in.
<>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
Nice about how much hp is expected and whats it going into?
We're expecting aroung 430-470 FWHP, about 380-400 RWHP. Going into a 2001 Tahoe. This thing is going to a torque monster. SCR should be about 11.6:1, on the cusp of not being able to run pump gas!
More fun will be had when the 5.3 comes out. I'm thinking an Iron LS1 (if cylinder walls sonic well enogh to bore that much) with a set of twins for a 72' Pinto!
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
I love my forged 408, even before the charger it was a beast. Looks like a fun build!
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
This was my LSX 427 SB
It got twin 76mm turbos and a Becks intake soon after, turned 1953.6 hp on 20lbs running Q16 race fuel has since been converted to alcohol and is close to 2300hp since i sold it!
The power adders!!
And this was my LSX 408 SB with 91mm single turbo on E85
This car made 1012.7 rwhp @ 18lbs
The top one was full race, the bottom i could drive daily!
Yours looks real clean, is it going in a show truck or driver?
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
