Neckbeard Posted December 15, 2012 Report Posted December 15, 2012 Always wondered this, Does it matter how many sticks you have? like, if i have 4x4gb or 2x8gb (both same speed) would it matter? Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
SnowDrifter Posted December 15, 2012 Report Posted December 15, 2012 Go with more sticks. It might be the same speed, but that is the speed of the stick. 4 sticks would be faster than 2. Think of it like 4 runs of 0 could carry more current than 2 runs ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Neckbeard Posted December 15, 2012 Author Report Posted December 15, 2012 okie dokie lol, it sucks though, I can only have certain height of ram, have to be careful Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
Tarball Posted December 15, 2012 Report Posted December 15, 2012 I would go with fewer larger sticks - in your case the 2 8gb sticks. My reasoning is future upgrade. Later you can by 2 more 8gb sticks for 32gb (assuming your board and OS support that much ram) instead of having to buy 4 x 8 gb sticks later. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Neckbeard Posted December 15, 2012 Author Report Posted December 15, 2012 well, this is gonna be my new build (way later, like waaaay later) http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 and i have this for a cpu cooler http://www.xoxide.com/thermalright-silverarrowsb-ecpucooler.html So, RAM must be short lol Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
BobbyG2 Posted December 16, 2012 Report Posted December 16, 2012 I would go with two low-latency sticks of RAM with that motherboard. Unless you're board has quad channel RAM (yours is dual channel) there will be limited-no performance increase with more sticks, unless of course the 4 sticks have more memory and your memory would be maxed out with only two sticks. These are currently the lowest latency memory per clock speed: DDR3-1600 (Motherboard Default): http://www.newegg.co...N82E16820226201 1866 (Motherboard sees as overclock): http://www.newegg.co...N82E16820231538 2133: (OC): http://www.newegg.co...N82E16820148625 2400: (OC): http://www.newegg.co...N82E16820313235 2800: (OC): Fastest: http://www.newegg.co...N82E16820231597 Very slightly slower latency, but much cheaper: http://www.newegg.co...N82E16820231640 You can always add another two sticks later on if your memory demands are higher than 8GB. I'd go with one of these coolers to keep from blocking your RAM slots. Very good reviews, I own an older Zalman they're great, and if the cooling from the Zalman is not enough, you're obviously very serious about your overclocking, and it's probably a good idea to go with watercooling anyways. http://www.newegg.com/Product/Product.aspx?Item=N82E16835118074 *New vehicle and system coming soon.*
