hiding tv wires when mounting on wall?
We've had our panasonic 50" plasma. on the tv stand ..but now i would like to put it on the wall. i know how to do the bracket but where can i buy a cheap wall faceplate for the hole in the wall behind the tv and the hole in the bottom.. how hard is adding the plug up there too? the "kits "are like 50+dollars i think the parts are alot cheaper some where online
monoprice.com
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
Honestly, if you haven't got much experience here, you can really muck some things up. If it's on an exterior wall, I wouldn't even attempt it (see: firebreak).
If you wish to attempt this, you can cut a hole in the wall with a template, and insert a contractor's box in there, drop the coax down to the opening at the bottom of wall...
I believe wall fish are like $50-75 from a licensed electrician.
I did these plenty of times at DirecTV, but I also fixed several attempts by homeowners, that would have otherwise cost them lots of money in repairs.
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
cut the drywall up and bottom get the wire connect it to thru the little box connect it to the scree on each side..screw itto the wall..?
Got the tv up on the wall last night. couldnt drop the wires because of a 2x4 goin across. going to get the big flexy drill bit later and. mount the plates soon
is that an exterior wall? That beam should be ab 18" off the floor, called a firebreak ;-)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
It's quite east I did it the other day. I fish lined the cable wire and hdmi cables through the wall and put a electrical outlet below the bracket.
Team Bass-Hz
get an electrician to move an outlet to right up behind where the tv is gonna go then mount a wire wall plate right next to it and then put another plate down low where your components are going
*edit* didnt see you said you already got the tv up!
