I'm pretty new to ice scene and I've got an old BMW 325i, I'm ready to install a decent install into it, I'm thinking maybe 8x12's or if I could get the room 8x15's as I said I'm pretty new to this and I'm well aware that the enclosure has to be right, this won't be for competition just self satisfaction, any idea's?? Many thanks.
You should start small, a pair of 12's, something along those lines. There's no way you could fit 8 12's or 15's in there without tearing the car apart and walling it off, which, even then, may still be tough. Welcome to the forums though!
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Thanks lads, yeah I've had the 2x12's and similar type installs, but here in England there pretty common and my BMW is just there waiting to be torn up and built to devastate the local communities! Lol so you don't think even with the right set up I could "shoe horn" the 8x12 in??
Welcome!
yah I agree, 8 12's in a 3 series bimmer is gonna consist of some sort of internal teardown. Lots of work, lots of wiring, lots of alts, batteries, etc. I'm thinking you want a daily driver, not a trailer queen show car, right? I know those trunks are fairly large, and instead of 8 12's, I would recommend 4 15's, arranged in some way that they can all stay in the trunk. Compound/Iso-Barik etc. I think with the right subs you could get 4 in there (subs that require small enclosures). And you can expect way more than the regular two 12's. Is your wall between the trunk and rear seat made of metal? On my 5 series, it was, and so was the rear deck. I cut those areas open which if it applies to you, is a must. Also, I believe the 740, or some 7 series bmw, has a high output alternator, like 240amps or so. It could be a bolt in. Might want to check that out too.
Like the poster above mentioned, ask questions, check out other builds, go to local shops and chat with the installers. I did that back in the day and learned a lot!
Id stick with 2 12's. 2 level 5's on 8k would be stupid loud for a trunk car.
Used to have a loud truck
what kind of subs are u gonna use what kind of amps first all what are you thinking of using
Firstly thanks guys for all the info, I'm taking in as much as possible! Lol right my bmw I think has 90amp alt, so either way has to be upgraded no matter what I decide, originally I was thinking 8x SA-12's and 2xsundown3500's, it's also been thrown in the mix about earthquakes, 4x15 dbxi's and 2xph5000 I'm not sure I want a trunk system a really like the idea of ripping those back seats out, although as I said I'm new to the big install's I'm not sure either about the "best" small enclosure sub's e wry dealer tells you there's are the best, so what do you guys think?? Thanks once again jay.
well, if you like the idea of ripping your seats out, then go for it i guess. take measurements of the available room for a box. if you have room for your intended 8 subs, then it could work. Many sub makers make great subs. What brand sticks in your mind that you wanna get? You dont have to say tho, this isnt a VS thread. But really, you cant go wrong with name brand subs. Just make sure you get subs that you like, that will work in the space permitted in your vehicle, are within budget, and will work with your amps.If you got time to work on the project, and dont think you're gonna change your mind down the road half way thru, or go broke (wire is expen$ive!!!), then why not?
Or, for an easier route thats less daunting, and perhaps a middle step, and a step up from the basic two 12's that you said you see around town there, is how bout getting a couple custom made subs, like spl design? then you can run a couple high powered amps, you;d be doing hair tricks possibly, it would take MUCH less time to install, perhaps cost much less, and you could maybe rip that back seat out to get more spl loaded into the cab. Or a couple 15s or 18s!
You Could do 4x18s or 4x15s but not 8x12s to much for a little car. :popcorn: also i'm tuned in
"The secret to creativity is knowing how to hide your sources." Albert Einstein
  • Who's Online   0 Members, 0 Anonymous, 1156 Guests (See full list)
