4th order in camaro wat do u think
kingofslowbass
im only using it for heat and strength not to sound deadene
94 z28 m6 cyber gray metallic custom pant with white strip black ss wheels and spoiler 249whp 295trq. in progress is a 4th order with 2 Obsidian 15s for SBN so subscribe to my youtube kingofslowbass to watch it all go together.
Well those subs are good 4th order subs so that is a plus.
How much sealed airspace do you have figured for the two 15's?
thats the thing i dont no how to tune things like that this is my first big build so im looking for as much help as possible i still need to measure the car on the inside but my friend has my tape measure in his car
im looking around 23hz-35hz with 28hz at my loudest note
peal and seal is the shit!!!!!!!
never used it got any tips on doing it i will be putting it over por15 rust paint will be a clean surface.
Do not use that stuff!! It will separate from the panel, and smell. Look it up on google and on forums. My friends Jeep had peel n seal in it, had to be removed since it gets hot in Florida, the heat caused it to smell really bad. Invest in some real Sound Deadener and do it right one time.
will do then ill take it back
I don't have a friend of a friend of a cousin that used peel and seal. But I myself have actually used it. 3 layers and no noticeable difference with 50% coverage. It wont stick very good and mine doesn't smell, but let's face it, you might as well just slap roofing tar on everything.
Also, 4th order with 2 fifteens in a camaro. I doubt it. But i wan't you to prove me wrong. Cause that would be badass if you can do it.
Each sub wants 2.0-2.5 sealed so there's 4-5 cubes sealed and double that for a 2:1 ratio with the ported side. Do you have 15 cubes available for this enclosure? One 15 maybe, or 2 12s.
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
