crazy how i drive past it every day to work, but never went inside the place lol
nice flex too btw!
Well you can't just drive in lol. But it's pretty crazy.
is that a prefab in front of the stage?? lol
No lol.
who did the buss bars? they look good
http://www.teamprojectdb.com/index.php/store
does great work and fast shipping.
Cleaned up my cluster fawk. Keep in mind this is a temporary setup. So I'm not cutting the wires to fit right now. Also the the project db is "backwards" since I had them setup for when I put the batteries to the back. Then it won't be backwards :) I need more amps so I can fill up the holes!
The before
The after
I'll rerun some more wire before scrapin to clean it up a little bit. But I don't to waste a lot on a temp gig. I'm also hoping to double power for it too.
I'm super happy with the busbars. Perfect bevel on the inlets, everything clean and smooth. This is my fourth purchase so far. Each one has been great. Also mechman and xs power ftw :) zero drop at idle!
Well I thought my window regulator broke or the track system, it randomly popped and the window fell :( Well I guess it was basshead problem. The three nuts holding the regulator on, fell off. Only managed to find two though :( But it's all back up and working. Also Did some work on the rear hatch to make it tighter. I basically spaced the latch off a little bit more. It helped. But not enough.
How it looked when I popped the cover off.
Taking the tailgate apart.
Geoff Cayemberg... aka Project DB
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Hey kyle..
If your door skin is still off...
You may also wanna replace the 3 rivets that hold the window assembly on... They are VERY nortorious of letting go with any type of big system.
Drill through them, and nut/pan head bolt them...... I was turned on to them by a member on here.....
Good work though bro...
Blazer builds are just popin up everywhere. I just got a 97 4dr 4wd. Work looks good must be nice havin all that IA credit. But what are you doing to the tail gate again
I was adding more tension to the to hold the glass down. I spaced the latch more almost a 1/4. Might add another washer.
This, does awesome work.
Hey kyle..
Thanks man. I was looking at those. I plan on doing that as soon as I have more time. One rivit is already loose lol. But thank you though.
Have some big updates. Just added some serious power and a bunch of goodies to install.
So, I've added more power, quite a bit more. Sound deadener, more bracing internally. Changing my front stage up a little for scrapin too. I've also added some air shocks.
Getting ready for surgery.
Broke a window track bolt trying to work on the doors.
More tweeters
Sealing up the windows. I'll clean the urethane up later.
9PM and still hot as fawk
Super amazing custom brackets.
  • Who's Online   0 Members, 1 Anonymous, 1188 Guests (See full list)
