sundown audio SA-8 V2 D2
ben_slates
I'm looking at buying a three SA-8s, however I don't know what the max wattage they are rated to take is and can the V2/D2 be wired down to 1 ohm?
YOu want D1's if your going to wire 3 of them into 1 ohm.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
3 xdual 2, wired in series/ parrell
Final load of 1.33ohm
3x dual 4 parrell/parrell
Final load of 0.66ohm
Idd get dual 2
Wirer to 1.33ohm
And find an amp rated for 2k @1ohm stable
If you want and u have the right box
You can look at amps upto 25-3k at 1ohm
My personal opinion is the sax2500 for 3 sa8v2 at 1.33
If you look up "2k XJ" he has the exact same setup
if you ever plan on running 4in the future get the d4 . reason is i started with 2 d4 v2 8's and now i have 3 and cant get 4 in this truck. so i will be seeing over a 2ohm load. i should have bought d2's. so if you wanna run 4 go ahead and get d4
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
  • Who's Online   1 Member, 0 Anonymous, 1635 Guests (See full list)
