2 12" Kicker L7 and 15" Kicker L7
whotry
I did try that but the OD of the 2 sub makes it a very tight fit with a 4" port and because the height is lower the port need to be wider
If you can post the measurement of the v and excact OD of the sub you have
I'll see what fits
I'll see what fits
I think this will be fine but is there any way you can make the port a bit wider say 5 to 6 inches tuned to 34hz
Thanks in advance
it doesnt work like that
the wider you go the longer it need to be, and the less net youll have
if you add an L2 to the port 11" long youll get down to 35hz, but to get it to 34hz some major changes need to made, witch is no problem
have you thought about firing the subs sideways or to the rear, its not optimum but another option
i am running the kicker zx750.1 i had with my 08 l712. swapped it for the 15 2011 model (rms750). i feel it can take some more
I recently bought 2 kicker L7s came on here and asked for help to design a box, a good person helped me on here i built the box but it doesn't have the power I need so I said what the heck might as well buy a 15 L7.
The car it's going inside is a Lexus GS300
My trunk is a bit weird but I'm sure I can build a box to fit. If there's anyone that can help me do some calculations I'm at work and I don't have access to a computer atm. My trunk has a small rectangle in the far back then comes out bigger.
The Max dem. for the small rectangle is. H-16.25 W-30.25 D- 12.25
After the small rectangle the Max dem. I can go is H-19.5 W-52.5 D-14. That's all inner dem. I've already subtracted .75 from all the measurements.
Now I'm a little confused on my options for my ports if anyone can help me out I would like my box tuned anywhere from 28-32 hertz.
I will be putting the two 12s on the outside and the 15 in the middle. If anyone can help me out on a sketch I would greatly appreciate it and I will be happy to post pictures while I'm constructing the box.
-whotry
was it 412 CVX who designed your box? you might want to move the port
  • Who's Online   0 Members, 0 Anonymous, 1737 Guests (See full list)
