The Big 3 (or 4??)
So I posted this in another similar topic and got no responses idk if it was the wrong one to post in or if just nobody seen it lol, so im will give this another shot.
The Big 3 upgrade:
1.I grounded my engine block to the frame(4g)
2.Upgraded power wire to alternator(4g)
3.Grounded battery to the frame(4g)
Now my question is do I ground my alternator to the frame too?? I just barely heard about The Big 4 (and there is only like 3 videos on youtube, but i dont think they explain to well???)
( and fyi the reason I used 4g is bcuz thats what I had to work with and also I only have 1 1800 watt amp, I WILL upgrade to 0g soon)
eddymack028
I personally did the Big 4 upgrade on my silverado.
I did:
Alt to battery
Engine block to chassis
Battery negative to chassis
Battery negative to engine ground.
You are missing the battery negative to engine block ground.
I'm doing the Big 4 myself
I talked to Mike Singer about it, and he told me in his testings, he saw much better results from the Big 4 over the Big 3.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I do a big 4 for reasons being i have an older car and the ground straps are bad or going bad.
I do the alt to battery.
Battery negative to engine.
Engine to chassis
You can never have enough grounds.
^^^posted as i was typing. lol
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Yeah, I'm doing it because my car is 15 years old, the grounding goes bad over time.
When it comes to electrical, there is no such thing as overkill, only never enough.
2003 Kia Sorento
Team Subsonic Lows
I haven't been on in a while, been "busy"
I have 1 more question that I forgot to ask. when I ground the engine to the battery do I use the same location as I have it grounded to the frame? or find a new location
eddymack028
I used the same locations and made a loop so to speak with the grounds.
So each location had 2 runs to the other spots and so on till all three were done.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
check out the ce electrical section on this forum. tons of info with testing to prove it.
ground the alt case to the frame all batts to the frame and do the alt power wire to batt. grounding the block is more of a waste of time. doesnt help much if any on the audio side of things. 4 gauge might not be big enough though. 1/0gauge is suggested and preferred by most. if your gonna be running anything over 300amps total 1/0 is needed.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Alright I get it, thanks :)
eddymack028
  • Who's Online   0 Members, 0 Anonymous, 972 Guests (See full list)
