Chevy Restoration Build
itll all get put together in about a week. then ill put it away for a while til i find a new bed. no pics til its completely done...
JOKING
sig22.jpgaim is jblackwell64www.jbcarworks.com
that truck would sound nice with a couple 15's in it
you have the air space for it.. anyway.. looks like you are doing a great job restoring it.
IM A LOW LIFE SCAMMER SO I WAS BANT....TEH HAMMA is NOT my friend
no way i have room for 2 15s lol. where would i put them??? im thinkin i have room for maybe 1 12 in a custom center console.. other than that im pretty closed off.
two words...
blow through!
um im puttin about 8 grand into this truck if you think im about to cut up a 3k paint job your effing nuts
ah man you'd only be cutting into the bed ..... it wouldn't effect the outside of the truck.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
the truck was dropped off at paint and body on tuesday february 12
Ok Got the cab corners and rockers glued in. Had to make new backers for them also.
Posted Image
Posted Image
Posted Image
Used the stud gun and got 95% of the damage to the front of the door out. Filled it and also fixed a couple other dents while I was at it. Then sprayed some primer on it and guide coated it.
Posted Image
Posted Image
After blocking, filling, blocking, filling, blocking, filling again and again my arm fell off:luke: But the dented pass side fender was ready for primer!
Posted Image
After Primer dried, I blocked it again and found 2 more small dents that got filled. Another 3 coats of primer were sprayed and now it is ready to be edged in and wet sanded for paint.
Posted Image
Also got the driver side fender blocked and primered. I will get it blocked and primer it again maybe today so it will be ready to edge it all in at the same time.
Posted Image
Posted Image
Found 7 more dents on the roof after primer and another blocking
Posted Image
Posted Image
Cab ready for paint tomorrow:clap:
Painted parts. Dont mind the bondo dust on them:naughty:
Posted Image
Posted Image
Posted Image
Posted Image
talk about doin some work.... damn.!!!! Gonna be a solid bowtie when you are done with !!!!!!
keep the pics coming - :)
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
