I have an oldsmobile 1999 eight-eighty and i have a 1200 watt brutus brz and a sundown sa 15 in a 4.5 cubic foot box tuned to 34 hz (its too big lol) but i have 400 bucks and the box barely fits in my trunk and i wanna get louder and pull hairtricks. Hopefully without purchasing a battery. Idk if i should downgrade to 12s which i really dont have a lot of money to do that right now i just wanna get louder and pull hairtricks like everyone else lol. i have 400 dollars i wanna know if i should buy another sa but that would require a battery so i need some advice and some direction.
Your not going to be doing hair-tricks like you see in video's on YouTube with only $400 unfortunately. I've spend over $3000 on my system, I've got a single 18 and I wouldn't be able to do one like that. I'm sure I'd get movement but it's not going to blow someone's hair around. If you want to get "Louder" then I'd suggest a new box. Have it engineered by someone like RAM Designs, PWK Designs etc. This will allow you to get the most from the woofer you have and will be of minimal cost. Keep the amp you currently have but consider upgrading electrical by doing the big 3, running heavier gauge wire to your truck etc.
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
if you want louder on the cheap, you can cut a huge ass hole in the box. that'll make it louder. Hair trick? No. Sound good? No. But itll be louder.
For $400, get a small honda or something and sell that 99. Then you can really get louder.
get a hatch bro. good luck in a sedan.
Arc Aduio XDI 2k
2x Alpine Type Xs
2x Optima Red Tops
"Big Three"
Alpine X303
Type R 6.5/ Kenwood Excelon 6x9
doesn't work like that bud
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
not easy to get loud in trunks to begin with even harder to get hair tricks can it be done yes are you going to do it with 400 not unless your some car audio god best bet would be to build a proper box and if you still want to get louder and pull hair tricks save a few grand
trunk car?
2 12s in the "right" box and way beefy subs. You still won't do hair tricks.
You must be doing it wrong LOL.
what i meant is he probably wont do them, i do mini ones on low power. =]
Why does every noob come on here and always says I wanna do hair tricks? Lol it's been said before, if you wanna pull hair tricks then put a fan in your backseat. Is your sub facing up? If so then that doesn't sound good in trunks. I would keep the sub or sell it and get 2 12s but have someone build design or build you a box, that will make a difference, big 3 and extra battery depending on your voltage. Pics would help as well man:)
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
