there is a open area where the clutch cylinder would go. A little tight, but is clear from the booster
I always look for the clutch cylinder hole thats a good tip to go by on any car thats not standard but could be :unsure: and make sure to use a grommet g/l..
any automatic car i would just drill and grommet a hole in the knockout panel for the clutch pedal.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
bro i have the same car as you, except its a 95 (same body style though) and the only way i got 3 runs of 4 gauge past the firewall was drilling into it. crawl down under the steering wheel area where the brake pedal is, toward the left there is a place to rest your foot...look up about a foot from there and you will see a metal plate that is precut from the factory but just needs to be punched out, thats where i drilled and it looks very clean and is far from any other wires,pipes or components. Why are you so worried about drilling into the car?
Too Much Stuff to list .
If it was me, I'd be worried about doing something stupid and drilling into something important on the other side -.-
  • Who's Online   0 Members, 0 Anonymous, 3773 Guests (See full list)
