DC Sound Lab
Well since it was mentioned to be a lower wattage amp, but when asked about that people got all offended. Let me all something else....
What are the differences between this and the 9k? (besides the 1k warts obviously)
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
Ive been told it has better parts and put out a better cleaner signal then the 9.0s and it supposely does around 12-13k at 1 ohm
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
7 Xs D3100s & 1 D6500
All Audio Techinx OFC 1/0
Doing 55s at 26hz!!!
i think its not fair to compare the 9k vs the 10k .
10k is a 12v amp.
9k has more potential
.02 cents
This is exactly what I was thinking and the reason why I got my 9k instead of a 10k.
10k is a 12v amp.
.02 cents
Have you not been reading the thread? Both amps are rated at 14v.
If it was that simple I wouldn't be asking about differences.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
10k is a 12v amp.
.02 cents
Your asking stupid questions and receiving stupid answers
If you dont know the difference between the 2 amps then its not the amp for you.
if you have to ask.....
Edited by heckvr4
  • Like (+1 Rep) 2
10k is a 12v amp.
.02 cents
I'm asking stupid questions? Maybe you lack intelligence and can't comprehend them, especially since you still think the 10k is a 12v amp after it's been mentioned various times that it rated at 14v.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Ok to clear up one thing that I think is eluding people.
When we say that the 10k is a 12v amp, all that mean is that you cannot run it on a 14v or 16v system. For those of you that dont know, a 14v system charges at 16.8v and a 16v system charges at 19.2v.
The 9k is stable UPTO 18v. This means that you can run a 12v system(charging at 14.8v), a 14v system(charging at 16.8v) or a 16v system(backed down and charging at 18v)
When we say that the 10k is a 12v amp, that does not mean that it is meant to be run at 12v or below. All 12v setups should charge 13.8v-14.8v.
  • Like (+1 Rep) 5
Also I'm pretty sure rail voltages are higher on 10k meaning they do max wattage in the 12-14v parameters ..,were as 9k does more at higher voltage.. I'd like to see some heads up comparison tests .. Ill trade anyone my 2-7.5s for 9s or 10s
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1861 Guests (See full list)
