DC Sound Lab
my only question is. is the amp a new model that is mono block or is it the 2 channel one that is on the DC website?
What amp are you talking about? The 10k and 9k are both mono blocks.
edit: I think your confusing it with the 12.0k
Edited by youngsticky
nevermind. had it confused with the 12k
edit: for some reason when i click on the 10k it gives me the specs of the 12k
Features Voltage 12.0K Output Power (RMS) 4 ohm 14.4V 1,200W x 2 2 ohm 2,100W x 2 1 ohm 3,400W x 2 .5 ohm 12V 4,200W x 2 .5 ohm 14.4V 5,500W x 2 .5 ohm 16V 6,500W x 2 Working Voltage 8.5V~16V Frequency Response Hz (-3dB) Hz 20~250 Signal to Noise Ratio dB 100 Damping factor 250< Efficiency @ 4ohm % 85% < Low Level Input V 6V - 0.2mV Line Output Yes Low Pass Filter Switchable ( @ 24 dB Slope) Variable Hz 35~250 Bass Boost
( @45Hz ) Switchable Variable dB 0 ~ 9 Subsonic Filter Switchable ( @ 24dB slope ) Variable Hz 10~50 Remote Level Control Yes Double Sided board 2 oz 3 oz Yes Indicator Power Yes Protection Yes Speaker & Power terminal Mold Type Yes Power Gauge 0Ga x 3 Fuses External Yes Heatsink Length mm (inch) 850(33.46)
Edited by Miguels
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
