Lowered Mazda B4000 riding stiff as a mofo (help)
I got a 1996 Mazda B4000 in a trade the other day and it rides insanely stiff. The rear end is sitting on the bump stops. I want a smoother ride without lifting it much because it sits relatively level with the front; a friend suggested cutting the bump stops; I've never heard of that before, and a mechanic I know said to get some lift shackles for it. I'd like to get some more opinions. What can I do to improve ride quality without totally ruining the stance?
rear wheel clearance:
driver side:
passenger side:
http://www.youtube.com/mrgeo20
-Bagged '98 S10
-Lowered '96 Ranger
-'01 Civic EX Boosted
-'99 Sierra, under construction
remove the rubber bump stops for one, looks like the passenger side only has one?, and the other get a C notch bolt on or weld on. but remove the rubber bump stops first
i have a lowered s10 and the rear used to ride really stiff until i removed the bump stops, now it rides a lot better
Remove the bump stops and put in a c-notch. Or if you think you will ever want to bag it, then have a step notch welded in.
I'm done with bagged trucks as daily drivers, thanks for the input though; it sounds like a good idea.
-Bagged '98 S10
-Lowered '96 Ranger
I was their when they put the 2 15s in a fiberglass box in it lol
nice truck did you trade the s10 for it?
Good lord sweet baby Jesus. Did you read the thread at all?
Bagged 1993 nissan hardbody
C - Notch
Where are you located in Mississippi ??
Cut those u bolts .. There sticking way down . When I had my Nissan I removed middle spring so top spring lays flat on over load also remove bumpstops
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Oh really, did Traffic Jams do the install? The box is just screwed into the back of the truck so i figured..
Yeah I traded the S10 for it. Just put two DAD subs in it yesterday.
C - Notch
Picayune, MS
-Bagged '98 S10
-Lowered '96 Ranger
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
