reg93f150 Posted January 2, 2013 Report Posted January 2, 2013 Damn sorry didn't see the relay part figured I'd try to jump the gun and Matbe throw out a quick solution ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
LoudPursuit Posted January 2, 2013 Report Posted January 2, 2013 You need to add a capacitor (not a car audio one) to your harness to stabilize the voltage. This is a common issue with mazdas and if you google Mazda flickering hid fix you will find many threads that show how to properly wire it. Headunit: Pioneer avh-1400dvd Subs: DC Audio lvl 4 18 with carbon fibre dustcaps Sub amp: Rockford T2500-1bdcp Mids & Highs: RF Prime 5.25's + Focal Polyglass 6.5s Highs Amp: RF T600-4 Batts: XS Power D975, XS Power D925 Alt: Mechman 270a Wires: Shok Industries 1/0, RF RCA's and Shok 12/8 gauge speaker wires Deadening: Second Skin TEAM DC TEAM SHOK
IH8PunkRok Posted January 3, 2013 Author Report Posted January 3, 2013 You need to add a capacitor (not a car audio one) to your harness to stabilize the voltage. This is a common issue with mazdas and if you google Mazda flickering hid fix you will find many threads that show how to properly wire it. i already have one in it. been in there since day one -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
LoudPursuit Posted January 3, 2013 Report Posted January 3, 2013 Do you have photos of how you installed it? I ran into this issue with my brothers car and it took hooking up the capacitor right into the factory harness and then from there i plugged in the relay harness. Headunit: Pioneer avh-1400dvd Subs: DC Audio lvl 4 18 with carbon fibre dustcaps Sub amp: Rockford T2500-1bdcp Mids & Highs: RF Prime 5.25's + Focal Polyglass 6.5s Highs Amp: RF T600-4 Batts: XS Power D975, XS Power D925 Alt: Mechman 270a Wires: Shok Industries 1/0, RF RCA's and Shok 12/8 gauge speaker wires Deadening: Second Skin TEAM DC TEAM SHOK
DR.TINGTING!!! Posted January 3, 2013 Report Posted January 3, 2013 I'm thinking there might be a bigger issue with your car's electrical system. HID's shouldn't effect the gauges I would think.
crunkjuice1 Posted January 3, 2013 Report Posted January 3, 2013 just because you already have relay and cap doesn't exclude them from crapping out even if they are relativly new. Get another relay and cap harness from DDM swap them out and see if it continues. The ones in there right now might be burning out from within and be causing problems.
mecaman86 Posted January 3, 2013 Report Posted January 3, 2013 its your computer it happened to my jeep dont let it go on long or it cost u lots of money
Babyjuice Posted January 3, 2013 Report Posted January 3, 2013 I just skimmed through all the post, but I had a similar problem in my f250 where the gauges went all crazy then went completely off then the truck died. It turned out to be a dead alternator and battery causing the issue. Not sure if that helps but thought it might possibly. BABYJUICE
White Lightning Posted January 3, 2013 Report Posted January 3, 2013 Not a good way to start off the New Year brother ... Best of luck with this Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
r1c3r Posted January 22, 2013 Report Posted January 22, 2013 try adding a 2nd capacitor inline with the first one. when it's not getting enough voltage you still might not have stabilized the voltage enough with one cap. i help out at xtreme HID in san jose when i'm free and i installed some on a tow truck with drls. ran a relay but it was so big and the hood opens i had to extend the wires of the relay. probably because it was so far from the battery and the wire gauge wasn't big enough i had to use 2 capacitors on the passener side.
