IH8PunkRok Posted December 31, 2012 Report Posted December 31, 2012 Driving home tonight my hids decided they wanted to be strobe lights. When this happened I had three warning lights flash and ding and all my gauges would die as if the car were off. The engine ran fine, no issues there Ddm tuning 55w hids 2005 dodge magnum has relay harness Anyone ever heard of such a thing? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
LukeYoung Posted December 31, 2012 Report Posted December 31, 2012 I've never had this issue. But it sounds like a bigger issue then just your hids if your gauges start dancing also. Check your ballets grounds. Check in car fuse panel and make sure their all tight. Check your alts power harness, ummmmm check your the relay panel under your hood also. 1998 Subaru Forester S DC 7.5K And DC 175.4 270XP DC Alternator One XS 5100R Three XS Power XP3000 All XS Power Wire Two SMD 18's I ONLY POUND BLOCKS AND PUSSY
reg93f150 Posted January 1, 2013 Report Posted January 1, 2013 Happens to a lot of people I know, simple thing we did to fix it was install a relay and its fixed. Had to do it on my moms jeep, friends f250, friends Cummins. I honestly just think it might be a relay to fix the problem. It wouldent hurt to check everything plugged in good and what not ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Kingcuong5o4 Posted January 1, 2013 Report Posted January 1, 2013 Do you have the relay to turn on with headlights? If so did you disable your drl
BeAlLsTaR13 Posted January 1, 2013 Report Posted January 1, 2013 It's a dodge, I have never had a set of HIDs go right in a dodge even with the relay harnesses Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
wellington Posted January 1, 2013 Report Posted January 1, 2013 Are they the cheap HID's? Sounds more like an electrical problem though. Did any of the gauges die before the HID's? I'm cool with my 55w $5 ebay H13 5k bulbs no more orange/yellow for me 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
Miguels Posted January 1, 2013 Report Posted January 1, 2013 my truck did that when i have a small alternator and would drop my voltage down... the alt wouldnt charge at idle due to bad wiring does it do it constantly or only when you are playing music and dropping voltage my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
DubNDodge Posted January 1, 2013 Report Posted January 1, 2013 What ever the issue, that isn't good at all. Constant igniting (turning on and off) will ruin the lifespan of the bulbs. I don't even use my remote unlock anymore just because of that. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
IH8PunkRok Posted January 2, 2013 Author Report Posted January 2, 2013 OK I'm going to try and answer all questions I have a relay so that isn't the issue My DRL have never been on They aren't cheap. Ddm is highly recommended It isn't a voltage issue as I had nothing running when it happened Now all that being said I removed the hids and a similar but new issue has arrived. The gauges will die and sometimes kill the engine. I feel I have a much bigger issue at hand -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
