justin0943 Posted January 4, 2013 Report Posted January 4, 2013 okay I picked up a t1000-1bd the older model which has a 150amp fuse, I'm planning on upgrading my alt to 130amp just wondering what kind of gauge of wire to run, kunkoncpetz kca 1/0ga is having a good deal for $48 for 20ft which is good for 250amp. my current setup is all stock I'm running 4ga to the amp which has a 100amp fuse.if I have enough I will run the 1/0ga to the amp.Just woundering is their any other brands out their that would be good for mysetup. 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
sprkn_ranger Posted January 4, 2013 Report Posted January 4, 2013 You would be fine with the knu KCA. As long as the wire you run is capable of handling the current the alt produces then your good. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
justin0943 Posted January 6, 2013 Author Report Posted January 6, 2013 You would be fine with the knu KCA. As long as the wire you run is capable of handling the current the alt produces then your good. yeah I'm only getting 130amp alt thats the biggest that I can get at my local autoparts place 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Pioneerchuck Posted January 9, 2013 Report Posted January 9, 2013 If you're never going to upgrade then doing 4ga would be fine but it never hurts to have a Good ground so I would go with the Knu KCA 0ga and be set up in case you decide to go bigger one day.
